ECU Flash on P1245 code
Old Feb 17, 2009 | 04:12 PM
  #46
awddyno's Avatar
here you go.
I'm sorry its so big. I don't know how to copy just the map itself. Also I meant under 80% throttle not 90%
Old Feb 18, 2009 | 05:02 AM
  #47
burnings's Avatar
Thanks! I will try it work later...
Old Mar 19, 2009 | 05:37 AM
  #48
flagg77's Avatar
Originally Posted by GST Motorsports
yes you can change the gear based tables to do that very thing.
Can you expand on this? I assume you mean to make changes to WGDC #2 (low gear range) as opposed to 1A or 1B.
- What is the low gear range? Just 1st and 2nd?
- Whats the difference between WGDC map 1a and 1b? is 1a warmup and 1b normal in the "high gear" range, whatever that range might be?
Thanks!
Old Mar 19, 2009 | 11:15 AM
  #49
GST Motorsports's Avatar
Thanks!
Check this thread out, its for 8/9 but the same applies to the 10:
https://www.evolutionm.net/forums/ec...t-control.html
Old Mar 19, 2009 | 12:32 PM
  #50
flagg77's Avatar
awesome, thank you
Old Aug 19, 2009 | 06:24 PM
  #51
Meth Addict's Avatar
Originally Posted by EVOXSILVER
If you have mbc or ebc you can also change all the passive wastegate duty cycle maps to 0. For me it worked great no more SES or Limp mode.
Since I'm having the same problem with my tru boost gauge I'll try this one in the morning.
mdknutsen
Jun 11, 2016 03:58 PM
evokid4life
Mar 25, 2013 10:13 PM
erald01
Mar 20, 2011 06:34 PM
zone4112
Sep 15, 2009 09:13 PM
NOTORIOUSLANCER
Feb 28, 2008 07:39 PM
