Will loading JDM SST Rom onto EDM ECU work?
Old Mar 3, 2009 | 01:47 PM
dleong's Avatar
Hi all,
I am a Newbie to EcuFlash and all assistance is appreciated.
I have an Australian Evo X SST (same as EDM) with Rom ID:53050006. As far as i know (which is not much), no-one has an EcuFlash XML definition for EDM SST Evo X.
Are there any plans for EcuFlash to support EDM (AU) SST Evo X models?
Will writing a JDM or US Evo x SST version of the Rom to my ECU work? Will the car run normally allowing me to start tuning with EcuFlash and my cable?
Thanks in advance,
Old Mar 4, 2009 | 10:37 PM
fbikawi's Avatar
no you cant.
becaus you cant open your rom, you cant copy the imobilizer code.
if you load a different rom into your ECU, it will have a different imobilizer so your car wont start.
not sure how the dealer can do that in case your ecu died?
Old Mar 5, 2009 | 04:41 AM
dleong's Avatar
Originally Posted by fbikawi
no you cant.
Thanks for the info/help
I guess i'm stuck with a openport cable i can't use until EcuFlash supports (AU) EDM SST Evo X.
EvoXEmma
Dec 27, 2020 01:18 PM
vaqusis
56
Sep 29, 2017 08:35 AM
EvilEvolution8
May 11, 2016 04:50 AM
EvilEvolution8
May 9, 2016 12:09 PM
