Evo X OBDII output parameters?
Old Mar 31, 2009 | 01:12 PM
mpboost's Avatar
Simple question, and hopefully someone knows:
Does the Evo X OBDII output include manifold absolute pressure data?
I know these cars are Mass Air Flow based, but I thought I noticed a MAP sensor on the intake too.
Anyone using a PLX Devices DM-100 OBDII scan device?
Old Mar 31, 2009 | 11:22 PM
Web9's Avatar
Yes. You can read MAP via OBDII
Old Apr 18, 2009 | 08:28 PM
helloderek's Avatar
Is anyone using the PLX OBDII mulit gauge on the Evo X?... how many ACTIVE parameters are there.. ie active display info can we see?... can wee see boost, oil temp, water temp, exhaust temp?.... I'm currently runninng Defi's but wld prefer the less gauge look so I'm looking at teh PLX OBDII system... any comments?
Old Apr 18, 2009 | 09:46 PM
mpboost's Avatar
It sounds like boost or at least MAP reading is an available output. Water temp should not be an issue since this is a standard OBDII output.
I have not seen a factory ECU that actually has EGT sensor input/output, however some of them do output calculated EGT over the OBDII port. If available, EGT (exhaust gas temp) output on the OBDII port will not be terribly accurate.
No oil temp.
They benefit of using the PLX Devices OBDII gauge is that you can daisy chain in extra sensor modules and have them display on the same gauge. So whatever info you can't get over the OBDII you can simply add a PLX sensor module for (i.e. wideband AFR, EGT, oil temp, etc.)
Old Apr 24, 2010 | 06:00 AM
JaCe's Avatar
Thanks for the info guys. I was looking at the PLX device and also the GReddy Informeter.
AndrewEvo
May 17, 2017 06:52 AM
defibros
May 10, 2016 12:49 PM
bsh
Nov 23, 2012 01:11 PM
LanceHer
Lancer Engine Management / Tuning Forums
Jun 5, 2009 12:56 AM
