drop-in filters -- results from tricking the MAF or less restriction?
Old Apr 14, 2009 | 03:01 AM
  #31
Mad_SB's Avatar
Originally Posted by Grip Master
Exactly what i was just about to say, great post. With heated wire, or heated Grid type MAF's the PCM varies the amperage give to the heater, in order to keep it at a constant temp. More air flow= more amps needed to keep the wire at the desired temp, which tells the PCM how many Grams/sec are going into the engine.
So, if you and gunzo are correct why does the afr go leaner, calculated load go down, and gram/s reported by the maf go down when going form the factory filter to an aftermarket filter like the works?
Old Apr 14, 2009 | 03:11 AM
  #32
Mad_SB's Avatar
Originally Posted by DTM
I think we are essentially saying the same thing then. I do not believe the sampling area will change with a filter element.
On your other point above...I'm not sure I can relate to the "magical waves"...but I am interested in looking at my old logs as well now when I did the IC and filter tests last year. I would love to see your logs. If you don't have time to post please email them to me as I would like to look at many different areas including TP, temp and the like. A pressure differential COULD mess with the readings slightly I guess... Not really sure. I have to do some digging.
Good post!
Hey Nick, logs are attached back on page 2 as is a link to the plots.
Kreeker
Sep 12, 2012 02:45 PM
PCToolsWiki
Nov 16, 2010 03:16 PM
acevo8
Midwest Region
20
Apr 29, 2009 11:05 AM
superman37r1
35
Mar 3, 2009 09:07 AM
EvoBig16G
Feb 16, 2006 08:23 PM
