Leaning out under WOT
Old Apr 20, 2009 | 07:59 PM
W1cked X's Avatar
sooooooo...has this issue been resolved yet???
Old Apr 21, 2009 | 01:07 AM
ImsoevoX's Avatar
Originally Posted by RogueValley
Sounds like the pump isn't getting the voltage it needs. It would make sense that since the car is under alot less load in 1st and 2nd that WOT would be ok and having problems in 3rd/4th. Either way, try digging and finding the thread about the poor soul who's pump lost voltage.
Yes...I am that poor soul...and no..I haven't been able to fix the problem..I can tell you right now..don't waste your money on the fuel pump relay,CHANGED IT..DIDN'T WORK..UGH I have the service owners manual..that gave me the order of operation for the fuel system. My next two things to look at are the fuel pump resistor and possibly the MAF..but Chris from AMS said the MAF was fine..they discovered that the fuel pump voltage doesn't kick up. My car is modded exactly like yours...I just wish I knew if the O2 sensor some how controlled a signal that changed fuel pump voltage..be sure to check the fuel pump resistor..now that this has happen to someone else I don't feel crazy...
Old Apr 21, 2009 | 03:59 AM
Mad_SB's Avatar
Did you and the OP both check to make sure you did not pop the line off the fuel pressure regulator? That would be the simplest explanation.
Next thing I would look at is the map sensor... X prefers the map sensor under WOT, if for any reason the voltage output of the map sensor is clipped, it will calculate a much lower load and you won't have the fuel you need, Don't think this will cause 15:1 under WOT though, fpr line certainly will though.
Old Apr 21, 2009 | 05:38 AM
Hiboost's Avatar
Both good points to check, failing that, I would just get a walbro fuel pump with adapter installed. Maybe run dedicated 8-10 gauge 12v line to the fuel pump from the battery, and have it activated with a 30 amp relay where the original power just triggers it. Usually the stock wiring is under sized and voltage falls off at high loads to the fuel pump although I haven't checked over what they use on the Evo X yet.
Old Apr 21, 2009 | 03:55 PM
turizmo01's Avatar
I checked the fuel pressure regulator line and it looks fine. I'm getting 10-12v from the fuel pump. Where are the fuel relays located at?
Old Apr 21, 2009 | 05:05 PM
04gsr's Avatar
on my x im test pipe, catback, open filter and upper ic pipe makin 317 and my injectors are maxed out up top. im 24psi tappered to 18psi. dont know if this helps
Old Apr 22, 2009 | 05:19 AM
burnings's Avatar
Did you try to bypass the fuel pump relay? This will essentially force the fuel pump to always run on high voltage and you can eliminate whether it is a fuel problem.
Old Apr 22, 2009 | 07:58 AM
turizmo01's Avatar
How do you go about doing this? I don't have a service manual, so I'm not sure where the fuel relays are.
Old Apr 22, 2009 | 08:22 AM
TTP Engineering's Avatar
The filling up of the gas tank was not a joke. Under half a tank, the fuel pickup starts to have a hard time picking up fuel which is fixed by adding more fuel to the tank.
Many road racers have experienced this first hand.
We have also experienced this on the dyno with multiple cars.
Old Apr 22, 2009 | 02:21 PM
turizmo01's Avatar
At first I thought you were joking til I read someones thread today about fuel cuts at 5500 rpms. I have this same exact problem if I have less the a half tank of gas.
Old Apr 22, 2009 | 05:51 PM
Excalibur's Avatar
Can you provide a link to this? I would like to read up on it. I'm running stage 2 and would like to know what's wrong if I find I have the same problem.
Would the walbro pump be a fix to this hypothetical issue?
Also, how do you know the injectors are maxed out? What size stock injectors do we have?
Old Apr 23, 2009 | 06:16 PM
turizmo01's Avatar
https://www.evolutionm.net/forums/ev...-happened.html
Well I purchased a Walbro 255 fuel pump. I hope this fixes the problem. I'll post results this weekend.
Old Apr 23, 2009 | 10:08 PM
flyguycfi's Avatar
Looks like we need a redesigned tank lol...
Old Apr 24, 2009 | 06:38 AM
turizmo01's Avatar
Ya obviously if you have to have more then half a tank of gas so you won't fuel cut out lol.
Old Apr 25, 2009 | 11:33 PM
ImsoevoX's Avatar
We have 650cc injectors..or at least that is what the max flow comes out to.
