EVOX MR EDM definition
Ok, so if I understand you correctly you can extract the data from lets say a USDM map and
adjust a stock EDM map with data from the USDM map using ecuflash?
I realize that you will not have a map that is realy optimized without logging a particular car and adjust accordingly but still like you said way better that stock...
/L-O
/L-O
I use JDM as a base ..
but I prefer my own
Defratos
Oct 11, 2009 02:49 AM
evo 9 MR JDM
Aug 11, 2009 01:03 AM
53050009, 53050009xml, definition, definitions, edm, evo, evox, files, flash, map, mivec, modifiy, mr, sst, switzerland, tables
