EVOX MR EDM definition
Old Apr 21, 2009 | 08:14 AM
defx2's Avatar
I Try to create an Xml definition for the EDM EVO X MR (53050009)
Several Tables seems now to be ok, but i cant find the right values for the axis definitions.
It would be nice if someone have a little bit time to help me finishing this xml.
Attached the last Version for the xml File.
Send me a PM if you need the Rom File. I'ts to large for an Attachement.
File Type: zip
Old Apr 23, 2009 | 10:50 PM
defx2's Avatar
Updated Maps
- High Octane Timing Map
- Low Octane Timing Map
- Mivec Intake 1
- Mivec Intake 2
- Mivec Exhaust 1
- Mivex Exhaust 2
- Ignition Warmup Retard
- Egr Timing Advance
File Type: zip
Old Apr 23, 2009 | 11:15 PM
defx2's Avatar
Sorry wrong File.
this ist the right one.
File Type: zip
Old May 4, 2009 | 01:04 AM
vosadrian's Avatar
defx2,
I am new to all of this, but I have just used your xml file with an AUDM EVOX SST. It works, but seems to be incomplete. Have you got a more up to date version of the 53050009.xml file?
Thanks for your efforts,
Adrian
Old May 4, 2009 | 07:06 AM
defx2's Avatar
Here is the last Version. It should be finished with all tables.
Please let me know if you found something wrong.
File Type: zip
Old May 5, 2009 | 01:11 AM
vosadrian's Avatar
Much Appreciated!?!
Have you used these definitions for any tuning? Can I be confident to use it without corrupting the ECU?
Cheers,
Adrian
Old May 5, 2009 | 07:11 AM
defx2's Avatar
At the moment i had and have no time to test these definitions. You can wait or use it at your own risk.
Old May 15, 2009 | 03:16 PM
evo_q8's Avatar
hmm.. i would love to use this. But Vosadrian's question is quite strong. I personally want this to be proved. I cant use this on my friends only car. And i await the final verdict! Cmon guys!
Thanks
Old May 17, 2009 | 05:12 AM
MC-Tuner's Avatar
I am interested too.
please help as i need to tune an EDM SST, and Manual EVO X.
Old May 18, 2009 | 07:25 AM
evo_q8's Avatar
Anything for the JDM roms?
Old May 18, 2009 | 03:11 PM
loevo's Avatar
Smile
Hi guys!
I had a chat with gunzo over on evoxforums.com. He has been providing base-maps for the USDM EVO X's incl the MR (SST) and he might be able to do the EDM as well if there is a few of us interested. He has gotten great feedback on his base-maps from the USDM users and he is doing this free to the EVOX community.
I do not know if gunzo is at this forum also but please chime in gunzo if you see this.
Otherwise drop gunzo over at evoxforums.com a mess and maybe ew can convince him to provide a base-map for the EDM EVOX...
/L
Old May 19, 2009 | 08:17 PM
gunzo's Avatar
Originally Posted by loevo
Hi guys!
/L
Yes .. I am here too .. Cobb is right .. in my pm to you .. I already stated the fuel quality is an issue .. so if you want a base map .. it is just that .. you still need to modify it to maximise the performance .. but it'll be definitely be better than stock ..
OK let me rephrase .. its 200% better .. I did a few EDM direct flash in of JDM maps without any modifications (stock for stock) .. the owners are so ecstatic that they don't even care its not optimised
Old May 20, 2009 | 02:47 AM
vosadrian's Avatar
Interesting gunzo... so you flash in a map from a JDM standard car into an EDM car and effectively turn it into a JDM car?
Cheers,
Adrian
Old May 20, 2009 | 03:50 AM
gunzo's Avatar
Cheers,
Adrian
Sorry can't be done .. I meant I used the maps on the JDM and transferred them 1 at a time ..
Old May 20, 2009 | 05:59 AM
loevo's Avatar
Ok, so if I understand you correctly you can extract the data from lets say a USDM map and
adjust a stock EDM map with data from the USDM map using ecuflash?
I realize that you will not have a map that is realy optimized without logging a particular car and adjust accordingly but still like you said way better that stock...
/L-O
