thinking of adding *more* water/meth
Old Apr 26, 2009 | 06:34 PM
meat_EVO's Avatar
My current setup has a AEM water/meth kit, one inlet with the big nozzle. I have seen people running dual nozzle setups and was wondering if anyone thinks i could benefit from this? i am running a 28psi tune on the stock turbo. I have 950cc injectors, fuelrail, and getting ready to add a fuel pump and fuel pressure regulator. it gets hott in va and i am running a very agressive tune I think.
Thanks for your input.
Old Apr 27, 2009 | 05:14 AM
meat_EVO's Avatar
and noone.
Old Apr 27, 2009 | 09:00 AM
Viciouz's Avatar
I don't think many people are running water meth right now and can't really help you out...
I am still lookign to get into it soon. Hopefully someone helps you out with your question soon.
Old Apr 27, 2009 | 11:45 AM
Mad_SB's Avatar
What size nozzle are you running (saying the big one does not help, need flow rate)?
Are you running 50/50 or 100%
If 50/50 then no.
If 100% then yes, but needs a retune to take advantage
50/50 needs to be a relatively small volume or your ignition system will struggle to ignite the mixture.
Please spend some time reading the WAI subfourm in the VIII and IX section, it will answer all of your questions and more.
Old Apr 27, 2009 | 11:53 AM
Boltz.'s Avatar
FCOTM Winner
IMO and experience, in the area of 500cc is good for the stock turbo with a system like the AEM. After that you'll experience diminishing returns and increase the need to refuel the system and the change of backfire.
Old Apr 27, 2009 | 06:13 PM
meat_EVO's Avatar
If 50/50 then no.
awesome, i am running 50/50, so thank you for your input.
Old Apr 27, 2009 | 07:39 PM
Evoryder's Avatar
i recently upgraded my 1 single nozzle to dual big nozzles...takes more time to fine tune, but noticeable difference and room for power. I run 100% meth
kevness
Oct 2, 2013 04:07 PM
ChaseH
Jun 29, 2012 12:55 PM
STi_kill3r
Apr 6, 2012 12:13 AM
Messidona
May 19, 2010 10:40 PM
Ceddy
Sep 28, 2009 06:01 AM
