Using Evoscan to determine why I pulled CEL (P1235)
Old May 7, 2009 | 11:29 AM
rogue's Avatar
This morning, using the updated PIDs, I logged my car for a little while driving from my house to the highway. During my ride I threw a code P1235, that almost all of us who are tuned have pulled at least once.
Anyway, after scanning the log I think I may have found the area where that made the ECU throw a cell. Please look at the attached log for the full run, I have highlighted the area I think may have been an issue.
Any ideas, or comments?
Old May 7, 2009 | 12:18 PM
burnings's Avatar
I dun think the airflow being logged is accurate.
Old May 7, 2009 | 12:21 PM
rogue's Avatar
Care to explain why? Or possibly send me your DATA.XML file so I can see what CAN ID you are using for Airflow?
- Daimon
Old May 7, 2009 | 02:50 PM
SiC's Avatar
SiC
- Daimon
Evoscan is pretty much still useless until the proper CAN ID's and formulas are found. Your airflow figures are off, if you use a generic OBD2 logger you'll know that it's suppose to be around 310 g/s max on a stock turbo (tuned ECU, bolt ons, etc.).
Anyways, it's really hard to determine anything from your logs since most of the numbers are off.
Old May 7, 2009 | 03:56 PM
rogue's Avatar
I thought we were making progress from the other evoscan thread... I may email you tonight, or today...
Old May 7, 2009 | 05:31 PM
WarmAndSCSI's Avatar
I adjusted my airflow check #2 map a bit between 3-4k and then copied it to airflow #1 and #3. I haven't had a CEL since
Old May 7, 2009 | 05:35 PM
rogue's Avatar
Ahh.. sounds good. Thanks.
mike594x
Mar 2, 2014 07:04 AM
Red Dragon
13
Sep 9, 2011 06:42 PM
healthynine
Jun 2, 2011 09:26 AM
vplukas101
21
Apr 23, 2010 06:33 PM
fuzy24
20
Jul 18, 2009 07:54 AM
