ECUflash and WORKS flashed ECU
Old May 9, 2009 | 09:57 PM
HB Speed's Avatar
Who said anything about ecuflash hehehe
ill talk to speed about ecu lockage
Originally Posted by nj1266
That is not the question. The question is this: Are you going to lock his ECU after you tune the car with ECUflash?
Old May 9, 2009 | 10:00 PM
nj1266's Avatar
Last I talked to him, he wants to be tuned with ECUflash. So you are not willing to commit in public that you will NOT lock his ECU.
Old May 9, 2009 | 10:02 PM
mike100's Avatar
HB speed is using open source EcuFlash tunes...I had mine done there and you can read/compare, edit, flash burn at will. I put it back to stock just the other day to bring it to the dealer for the hood latch cable campaign. You own your code..no monkey business.
just be sure to read your stock tune before hand..oh wait...works has it...but not to worry, a lot of people have the oem flashes now.
Old May 9, 2009 | 10:11 PM
nj1266's Avatar
that i good to know
Old May 9, 2009 | 10:15 PM
HB Speed's Avatar
We use all sorts of software for X's
Ecuflash, accessecu, and a few others
I prefer not to lock an ecu if I can trust the customer not to mess with the tune
Old May 9, 2009 | 10:18 PM
SpeedI2acerX's Avatar
I say use whatever works best
HB got an openning yet? i can do it Monday or tomorrow
Old May 9, 2009 | 10:24 PM
mike100's Avatar
I'm not inclined to get too creative with it (raised the rev limit 150 rpm)...besides it survived a pretty good two day track weekend at Spring Mtn. in Pahrump and a couple of thousand street miles with no problems..pretty happy with the conservative tune you did a couple of months back. The tailpipes don't even need to be wiped clean every two weeks anymore.
Old May 9, 2009 | 10:29 PM
HB Speed's Avatar
Old May 9, 2009 | 10:45 PM
I'm sold! Hook me up HB asap!
Old May 9, 2009 | 10:50 PM
HB Speed's Avatar
Trying to fit you in we are booked thru mid June right now...
Im trying to find an opening to hook an evo brother up !!
Old May 9, 2009 | 10:54 PM
Whatever you can please that'll be ggggggreat
Old May 10, 2009 | 05:02 PM
here's an option. ive been wanting to get Cobbs AP, will using that lock up my ECU?
Old May 10, 2009 | 05:11 PM
HB Speed's Avatar
Cobb flashed ECU's cannot be read with ecuflash.
But it dosent matter anyway
Cobb has software you can use to tune your own ECU
Cobb has software to allow professional Tuners to tune your ecu
I like the AP for its ease of use, ability to swap maps without lugging a laptop around and to datalog without a lap top.
Pro tuned maps are "locked" and for good reason, it prevents the end user from messing with the tune and blowing the car up.
the "race" software is locked to one AP and can be used to tune your own Ecu, since then its on the user if the motor tanks
Once a car is tuned there really isnt much need to mess with it.
I dont see the huge issue with "locked" and unlocked ecu's.
HB Speed's Avatar
Old May 10, 2009 | 05:40 PM
well my problem is that EDO gave me a p2 stockish map for a stock car and i have all the mods listed on my sig, will i have a problem? or should i just wait for YOU to tune it?*hint hint*
