Help!! P0302
Old May 14, 2009 | 06:25 AM
ImsoevoX's Avatar
Help!! P0302
I was driving along this morning when all of sudden I got a cell..I pull out my pocket scanner and it tells me that I have a P0302..it reads it as a misfire and also mentions something about O2 sensor..I was wondering has anyone else had this problem..also..if I do have a bad o2 sensor which one is it?
Old May 14, 2009 | 07:41 AM
WarmAndSCSI's Avatar
P0302 is a misfire on cylinder 2, the 2nd cylinder from the timing chain side. Check the coilpack and plug. Then check the fuel injector for correct resistance across the coil. Lastly, check compression.
Old May 14, 2009 | 07:51 AM
detroit pistins's Avatar
also, try swapping the 2nd injector to a different cylinder just to see if that code appears on a different cylinder instead. and if it still occured then do a "leak down test" to make sure ur valve seals are good and no issue there. gl
Old May 14, 2009 | 07:55 AM
Also a bad primary O2 sensor can throw off fuel trims and cause cylinders to run extra lean or rich, causing P030x codes.
Old May 18, 2009 | 10:48 AM
EM@WORKS's Avatar
How do your plugs look?
Old May 18, 2009 | 09:49 PM
turizmo01's Avatar
Have you fixed this yet?
Old May 21, 2009 | 10:10 AM
silex's Avatar
I just got this code on my Evo IX although it told me it was a misfire on cylinder 1 so iono. I plan to check the spark plugs first and make sure they're all good and basically follow them back to the wires and coil packs. The fuel injectors should not be the culprit. Your O2 sensor could be bad too.
Basically you and myself are probably running richer than we should and thus are fouling plugs. That's the gist of it anyways.
Old May 21, 2009 | 10:13 AM
newMRevoNyne's Avatar
Are you up to date on your dealer re-flashes?
Old May 23, 2009 | 04:27 PM
ImsoevoX's Avatar
I just like to inform you all..the engine blew..so...time for a new X...lol
Old May 23, 2009 | 04:51 PM
hawaiian_evo's Avatar
wth? howd that happen??? sorry bout the motor man best of luck
Old May 24, 2009 | 10:36 AM
hotrod2448's Avatar
I'm guessing it's related to this:
Originally Posted by ImsoevoX
Ok, so I stopped into AMS yesterday to get a custom flash. After a few minutes they informed me that my car couldn't take the tune because it was running to lean. They did me a huge favor "which I'm super grateful for" in finding out that the fuel pump doesn't change voltage when the car is at full throttle, hence running too lean. The AFR is at 14 and that was pulsing the injectors 100% at the stock map again. They didn't have a full service manual to tell them what exactly controls the voltage on the fuel pump. Has anyone had this problem besides me!? I am really at a loss.
My mods so far are AMS FMIC, UICP and base flash. I also have a UR full turbo back with test pipe and cone filter. I really need to find out how to get more fuel to the engine..I don't want to blow it..On another not I did notice that since I'm back on the stock map the car isn't pulling timing like it was before I brought it in..This is going to make it hard to convince the dealer that there is something wrong with the fuel system..I really need to know what controls that..or what tells the fuel pump to dump more fuel..
PROBLEM SOLVED...so I decided to ohm out all the relays to see if they were bad..I pulled every single one....one by one of course..lol..and they all were good..so I am thinking..wtf.. Then I decided to take a look at my boost gauge. For power I wrapped wire around a fuse and stuck it inside of the fuse panel in the passenger compartment. I checked the hot lead and the ground...bingo there it was.. the ground was grounding out on something..the wire was hanging..but touching another wire...to top it off the wire for some reason was a bit frayed. So I tighten everything back up and put it in it's place..took the car for a spin..and bada bing bada boom..car is pulling like no tomorrow..well..for what can be expected on the stock fuel map..but everything is ok...
THANKS GUYS FOR ALL YOUR HELP!!!!!!
So, was it the fuel pump fuse you tapped and the gauge wiring was shorting it out? It's a little unclear.
Old May 26, 2009 | 05:43 PM
silex's Avatar
I haven't heard of this issue. Is it a common problem on a stock fuel pump? Walbro 255lph as well? If this is any lesson, it's to be sure that you always have a working wideband to monitor your AFR's with.
Old May 27, 2009 | 09:47 AM
Chuckdimpala's Avatar
How could these mods cause it to run so lean is it because of the base flash?? Cause with just the mods and NO flash wouldn't the car still be running in the 10's or 11's AFR????
Old May 27, 2009 | 09:57 AM
just an fyi, on my ix after i put the 3'' tbe without the flash i started noticing boost creep around 5k rpm, not sure if this information coudl u to anything.
the turbo will definitly breath alot better with the exhaust.
Old May 27, 2009 | 10:19 AM
hotrod2448's Avatar
It doesn't have anything to do with the mods IMO. He was making it sound like something he wired was shorting out the fuel pump preventing it from going into rising rate when it should.
