Help!! P0302
Old May 28, 2009 | 06:27 AM
ImsoevoX's Avatar
I have heard the critial error I made was installing things like the TBE, FMIC, and intake after I got a baseflash and waiting to get the car retuned.. I think on of the gentlemen from Mach V chimed in another forum and said, the ECU can really learn your new mods unless you get tuned for them..so I will be wise..get all my factory flashes first..then throw on all the mods..then get tuned...second car..I have to be smarter this time around...but I will not be modding for some time... :-(
Old May 28, 2009 | 09:28 AM
Chuckdimpala's Avatar
Oh so I'm assuming just putting upper and lower IC pipes and exhaust with a drop in wont hurt anything on the stock ECU ??? Just if you did it after a base flash I guess then that could hurt it because the AFR was higher than how they come stock spitting fuel out of the tailpipes...
Old Dec 8, 2012 | 11:39 AM
cdmassee's Avatar
it has less to do with mods and more to do with a crappy fuel relay that mitsubishi put in their cars.
this is where it is.
sorry for the long link.
http://www.google.com/imgres?um=1&hl...r:11,s:0,i:120
the relay fails to send more voltage to the pump and this causes the engine to not get enough fuel.
This happened to me when I only had an intake and a test pipe on my car. (no wideband so I didn't know it happened) ran it with the bad relay for maybe a week.
then the motor came apart a month or so later.
so basically check your relays and get a wideband. its worth it.
but to be on topic this could also cause the po30(1 2 3 or 4) code.
barneyb
Feb 28, 2017 07:18 PM
Johnny402Ne
Lancer Troubleshooting
Dec 2, 2012 07:50 AM
AJsGenerX
May 8, 2012 05:54 AM
steven88
41
Dec 15, 2011 06:50 PM
Russ444
Lancer Engine Tech
12
Aug 9, 2011 04:42 PM
