ECU Flash XML Definition Needed for EDM EVO X GSR
Old May 19, 2009 | 02:00 AM
MC-Tuner's Avatar
Hi there,
I would like to know if anyone has the XML Definition to open the EDM EVO X ROM. I also would like to know how to edit it it as i don't now how to do it.
Any help will be much appreciate it.
Old May 24, 2009 | 07:34 PM
tephra's Avatar
what romid?
Old May 25, 2009 | 12:54 PM
AIK's Avatar
AIK
MC-tuner
You can find it on openecu.org->forums->mitsubishi
tephra
I have read and flash more then 10 EDM EvoX with 5MT, but i have seen only one ROM - 54030007.
Old May 25, 2009 | 06:37 PM
tephra's Avatar
well your not looking hard enough :P
53040010 is my romid
Old May 25, 2009 | 09:23 PM
AIK's Avatar
AIK
I think that all 530400XX have the same table adresses. Someone asked xml for 53040008 on openecu. I rename my xml and his hex was opened correct.
Old May 26, 2009 | 01:52 AM
tephra's Avatar
nah 53040010 is diff xml again...
Old May 26, 2009 | 04:19 AM
MC-Tuner's Avatar
Dear All,
Thank you for your information. the file ID is:
53040008
I found a file in the Open ECU Forum but the only problem is that the RPM axis is not right.
Old May 26, 2009 | 11:28 AM
AIK's Avatar
AIK
MC-tuner
This xml have some problems in idle and boost correction tables. But it don't deprive of possibility to tune car. You can see base 53040007 xml below and 53040008 xml which based on 53040007. You need copy both to your rommerdata.
<rom>
<romid>
<xmlid>53040007</xmlid>
<internalidaddress>5002A</internalidaddress>
<internalidhex>53040007</internalidhex>
<make>Mitsubishi</make>
<market> EDM</market>
<model>Lancer</model>
<submodel>Evolution X</submodel>
<transmission>5MT</transmission>
<year>2008</year>
<flashmethod>mitsucan</flashmethod>
<checksummodule>mitsucan</checksummodule>
<memmodel>M32186F8</memmodel>
</romid>
<include>evo10base</include>
<!-- <include>52680015_mods</include> -->
<!-- **Timing** -->
<table name="High Octane Timing Map" address="5590f">
<table name="Load" address="60f7a"/>
<table name="RPM" address="616f8"/>
</table>
<table name="Low Octane Timing Map" address="55b11">
<table name="Y" address="616f8"/>
</table>
<table name="MIVEC Intake #1" address="5dd21">
<table name="Load" address="61588"/>
<table name="RPM" address="615b8"/>
</table>
<table name="MIVEC Intake #2" address="5db21">
</table>
<table name="MIVEC Exhaust #1" address="5e121">
</table>
<table name="MIVEC Exhaust #2" address="5df21">
</table>
<table name="Ignition Warmup Retard" address="5b8a9">
<table name="RPM" address="60f46"/>
</table>
<table name="EGR Timing Advance" address="572b9">
<table name="Load" address="61524"/>
<table name="RPM" address="6150a"/>
</table>
<!-- **Fuel Control** -->
<table name="High Octane Fuel Map" address="55027">
<table name="Load" address="60f00"/>
<table name="RPM" address="60eda"/>
</table>
<table name="Low Octane Fuel Map" address="552d7">
<table name="Load" address="63cca"/>
<table name="RPM" address="63d22"/>
</table>
<table name="Unknown Fuel Map" address="5517f">
</table>
<table name="___Max Rich AFR Clip vs Coolant Temp" address="5a190">
<table name="Coolant Temperature" address="5d290"/>
</table>
<table name="Fuel Injector Scaling" address="536cc"/>
<table name="Injector Battery Voltage Latency Compensation" address="556d0">
<table name="Battery Voltage" address="60e6a"/>
</table>
<table name="Injector Base Latency" address="53000"/>
<table name="Evap Map #1" address="55d13">
</table>
<table name="Evap Map #2" address="55f15">
</table>
<table name="___Open Loop Load Low Octane #1" address="555da">
<table name="RPM" address="60d76"/>
</table>
<table name="Open Loop Load High Octane #1" address="574cc">
<table name="RPM" address="60d7a"/>
</table>
<table name="___Open Loop Load Low Octane #2" address="555c2">
</table>
<table name="Open Loop Load High Octane #2" address="574b4">
</table>
<table name="Cylinder Fuel Trim #1" address="57db1">
<table name="RPM" address="619d6"/>
</table>
<table name="Cylinder Fuel Trim #2" address="57f9b">
</table>
<table name="Cylinder Fuel Trim #3" address="58185">
</table>
<table name="Cylinder Fuel Trim #4" address="5836f">
</table>
<!-- **Turbo Control** -->
<table name="Boost Control Load Offset" address="53484"/>
<table name="Boost Target Engine Load #1A (High Gear Range)" address="58e45">
<table name="Throttle" address="62616"/>
<table name="RPM" address="62594"/>
</table>
<table name="Boost Target Engine Load #1B (High Gear Range)" address="58eef">
</table>
<table name="Boost Target Engine Load #2 (Low Gear Range)" address="573f5">
</table>
<table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58cf1">
</table>
<table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58d9b">
</table>
<table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5734b">
</table>
<table name="___Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a"/>
<table name="___Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="5467a"/>
<table name="Reactive Solenoid Turbo Boost Error Correction" address="58cd8">
<table name="Load Error" address="625bc"/>
</table>
<table name="___Reactive Solenoid Max Total Upward WGDC Correction vs TPS" address="58cc6">
<table name="TPS" address="625f8"/>
</table>
<table name="___Reactive Solenoid Max Total Downward WGDC Correction" address="5346c"/>
<table name="Passive Solenoid Base WGDC Map #1A (High Gear Range)" address="5a1ca">
</table>
<table name="Passive Solenoid Base WGDC Map #1B (High Gear Range)" address="5a1e0">
</table>
<table name="Passive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5a1f6">
</table>
<table name="___Boost Control RPM Per MPH Xover (Gear Based)" address="5466a"/>
<table name="Boost Limit" address="555b4">
<table name="RPM" address="6155e"/>
</table>
<table name="Boost Cut Delay Timer" address="53068"/>
<!-- **Throttle Control** -->
<table name="Throttle Map #1" address="50b64">
<table name="Unknown" address="613d4"/>
<table name="RPM" address="61326"/>
</table>
<table name="Throttle Map #2" address="5118e">
</table>
<table name="Throttle Map #3" address="517b8">
</table>
<table name="Throttle Map #4" address="51de2">
</table>
<table name="Throttle Map #5" address="5240c">
</table>
<table name="Throttle Conditional Switch" address="5494e"/>
<!-- **Limits** -->
<table name="Rev Limiter" address="5305e"/>
<table name="Stationary Rev Limiter" address="53442"/>
<table name="Speed Limiter" address="53062"/>
<table name="Airflow Check #1" address="5e94d">
<table name="Throttle" address="62494"/>
<table name="RPM" address="6246c"/>
</table>
<table name="Airflow Check #2" address="5ea43">
</table>
<table name="Airflow Check #3" address="5eb39">
</table>
<table name="Airflow Check #4" address="5ec43">
<table name="TPS-Related" address="624dc"/>
<table name="RPM" address="624b6"/>
</table>
<table name="Torque Limiter #1" address="6380f">
<table name="TPS-Related" address=" 62494"/>
</table>
<table name="Torque Limiter #2" address="63905">
<table name="TPS-Related" address="62494"/>
</table>
<table name="Torque Limiter #3" address="639fb">
</table>
<table name="Torque Limiter #4" address="63af1">
</table>
<table name="Flow Check table" address="60a8d">
<table name="TPS-Related" address="62a78"/>
<table name="RPM" address="62a60"/>
</table>
<!-- **Knock Detection** -->
<table name="Knock Filter #1" address="56703">
<table name="X" address="611b4"/>
<table name="Y" address="61198"/>
</table>
<table name="Knock Filter #2" address="5692b">
</table>
<table name="Knock Filter #3" address="56873">
</table>
<table name="Knock Filter #4" address="567bb">
</table>
<table name="Knock Filter #5" address="5664b">
</table>
<!-- **IDLE** -->
<table name="Idle RPM #1 vs Coolant Temp" address="5f308">
<table name="Coolant Temperature" address="60ff0"/>
</table>
<table name="Idle RPM #2 vs Coolant Temp" address="5f2fc">
</table>
<table name="Idle RPM #3 vs Coolant Temp" address="561ee">
<table name="Coolant Temperature" address="6122c"/>
</table>
<table name="Idle RPM #4 vs Coolant Temp" address="5a874">
</table>
<table name="Idle RPM #5 vs Coolant Temp" address="561fa">
</table>
<table name="Idle RPM #6 vs Coolant Temp" address="5a8a2">
</table>
<table name="Idle RPM #7 vs Coolant Temp" address="5a896">
</table>
<table name="Idle RPM #8 vs Coolant Temp" address="59df0">
</table>
<table name="Idle RPM #9 vs Coolant Temp" address="59de4">
</table>
<table name="Idle Adder #1 vs Coolant Temp" address="6098c">
<table name="Coolant Temperature" address="61006"/>
</table>
<table name="Idle Adder #2 vs Coolant Temp" address="6099A">
</table>
<table name="Target Idle #1" address="533c6"/>
<table name="Target Idle #2" address="53c74"/>
<table name="Target Idle #3" address="53c76"/>
<table name="Target Idle #4" address="532de"/>
<table name="Target Idle #5" address="53d70"/>
<table name="Target Idle #6" address="532da"/>
<table name="Target Idle #7" address="532e0"/>
<table name="Target Idle #8" address="53d72"/>
<table name="Target Idle #9" address="532dc"/>
<table name="Target Idle #10" address="54012"/>
<table name="Target Idle #11" address="54016"/>
<table name="Target Idle #12" address="54886"/>
<table name="Target Idle #13" address="54888"/>
<table name="Target Idle #14" address="54ab6"/>
<!-- **Misc** -->
<table name="ECU ID" address="5002A" type="1D" scaling="ECU ID"/>
<!-- *** MUT *** -->
<table name="MUT Table" address="3ea64">
<table name="X"/>
<table name="Y"/>
</table>
</rom>
<rom>
<romid>
<xmlid>53040008</xmlid>
<internalidaddress>5002a</internalidaddress>
<internalidhex>53040008</internalidhex>
<market>EDM</market>
<submodel>EVO</submodel>
<transmission>SST</transmission>
<year>2008</year>
</romid>
<include>53040007</include>
</rom>
Old May 30, 2009 | 03:18 AM
bobik's Avatar
tephra do you need 010 xml ?
Old May 30, 2009 | 07:21 PM
tephra's Avatar
nah ive done up a 53040010 xml
Old Sep 20, 2009 | 10:20 AM
MC-Tuner's Avatar
Guys,
Thanks for all the help.
now i have a 53040010.hex file that i cant find XML for.
any help please here.
Old Sep 21, 2009 | 03:34 AM
MC-Tuner's Avatar
I am in great need of the:
53040010.XML
Can you please post it?
thx
Old Aug 4, 2014 | 06:11 PM
rpizarro's Avatar
TephraXMod V2
I need the rom tephraxmod v2 for my Evo x Ecu ID 5403007 EDM I pay your cost please where pay
vaqusis
56
Sep 29, 2017 08:35 AM
etdirect
Jun 24, 2017 06:38 PM
LFT
Aug 4, 2016 10:02 AM
gudmundur
Feb 21, 2016 02:50 PM
mynew03evo
Mar 25, 2014 02:39 PM
