Knock after shifting to next gear
Old Jul 15, 2009 | 06:31 AM
Bob_tm's Avatar
While WOT pull from 2000 to 7500 all seems good. But after shifting to next gear there are always 4-5 knocks at the beginning of acceleration.
Is it normal?
Evo X 5MT EDM, +35 C. Turboback, stock IC, EVC 6 boost.
Old Jul 15, 2009 | 06:38 AM
HybridKOOP's Avatar
Is it normal?
Knock counts? Or knock retard? Knock is not "normal" and should be prevented as much as possible... but most cars will experience a slight bit of retard here in there on bad gas, hot summers, etc. My setup was tuned very well, and I got some BP gas last night that registered a knock retard of .3 to .7 max which is considered very very minimal...
We need to know more details about your setup, boost, fuel used, etc.
- Louis
Old Jul 15, 2009 | 06:44 AM
Bob_tm's Avatar
Knockcount.
Boost 20 psi (overboost to 24 while shifting). (load 227 and 250 while overboost)
93 oct (euro 98)
Afr 11.2 - 11.3
Timing +1 degree over stock EDM timing.
Old Jul 15, 2009 | 07:44 AM
tephra's Avatar
its probably the shift...
you can tune it out...
Old Jul 15, 2009 | 08:11 AM
Bob_tm's Avatar
How? Less timing or something else?
Old Jul 15, 2009 | 06:21 PM
tephra's Avatar
if it does it consistantly then yes less timing when it first pops up..
if its random then dont worry about it...
Old Jul 15, 2009 | 07:23 PM
nj1266's Avatar
It is shift knock from engine/tranny movement that the knock sensor picks up. I would not worry about it. The knock sensor is simply a ruggerized microphone and sometimes it picks up engine/movement noise as knock. This is very common. If you are going to retard timing everytime this happpened, then you will end up with negative timing.
Old Jul 16, 2009 | 12:55 AM
Bob_tm's Avatar
Thank you!
Old Jul 16, 2009 | 02:08 AM
KOTT's Avatar
А ты боялся
Old Jul 16, 2009 | 04:22 AM
Bob_tm's Avatar
Somebody change knock filters for stiffer engine mount?
Old Jul 16, 2009 | 04:54 AM
Hiboost's Avatar
I'm thinking the AMS "street" version of the front motor mount might be a good compromise to stiffen up the engine movement without getting excessive vibration. I've got the race version and it's a bit too much for daily driving but I got used to it. The engine flops around much less though and will improve shifting feel especially when near the limit around turns and movements that cause weight transfer.
Old Dec 6, 2009 | 12:17 PM
Danieln's Avatar
I experience also this issue after I install a engine dumper in order to decrease the movement of the engine under on/off throttle conditions.
I get a knock signal after gear change in WOT.
I am thinking to lose the dumper and to install some ralliart engine mount bushing but there are very strong also.
Old Dec 7, 2009 | 07:32 AM
LVSBB6's Avatar
Is there any way to prevent boost spike in-between shifts? This happens to both GSR and MRs.
Old Dec 7, 2009 | 07:37 AM
thatsMR2u's Avatar
mine went away when i switched to a tial and took out the clutch delay valve
Old Dec 7, 2009 | 07:40 AM
thatsMR2u's Avatar
Is it normal?
when you datalog either match up the numbers to your map or try taking the car up to redline and shifting slowly and compare the timing numbers- see if the car is really pulling timing and where- because its probably just phantom knock
