Wideband Positioning in Stock Downpipe?
Old Aug 20, 2009 | 07:06 PM
tephra's Avatar
I can trust it, because if I see a funny reading I know to ignore it...
like if I tuned for 11:1 and then all of a sudden I was seeing 10:1 I know the LC1 has probably stuffed up... and I can ignore that log...
HOWEVER with narrowband sim, the car doesn't have that filtering capability, it places complete trust in the signal being correct... it doesn't ask me first hehe
space is also an issue with the 02 sensor
Old Aug 20, 2009 | 07:11 PM
LaXGSR's Avatar
Hmm so if I always had a wideband gauge mounted, and occasionally checked WOT AFR's to make sure the LC-1 was accurate, then could it be trusted as a narrowband simulator? I'd rather not weld a bung into the stock downpipe if I dno't have to
Old Aug 20, 2009 | 07:15 PM
tephra's Avatar
well in all honesty I am probably being over-dramatic..
narrowband only revolves around 14.7:1, which the LC1 seems to be fairly good at getting right.. ie its doesn't need to be that accurate.
hey - give it ago, you will find the heater for the narrowband an issue, you *might* get away with disabling that bit to disable the heater for the front narrowband thou...
Old Aug 20, 2009 | 08:17 PM
stokEd's Avatar
Originally Posted by LaXGSR
This oxygen sensor socket is essential for getting the stock front o2 sensor off when still installed on the car:
http://www.harborfreight.com/cpi/cta...emnumber=97177
OT: lol... I've got that exact same tool from Harbor Freight. Disposable tools FTW.
Old Aug 20, 2009 | 08:34 PM
tephra's Avatar
cheap tools that work FTW
Old Sep 1, 2009 | 10:53 AM
dontek's Avatar
Subscribe..
I am also interested in possibly replacing the OEM narrowband with my LC-1.
Old Sep 1, 2009 | 10:55 AM
dontek's Avatar
What do you mean "stuffed up"? How is space an issue?
Old Sep 1, 2009 | 02:48 PM
Hiboost's Avatar
I think that's UK/Aussie English for "messed up".
Old Sep 1, 2009 | 04:00 PM
tephra's Avatar
yup
Old Sep 2, 2009 | 02:13 PM
funks's Avatar
If I could do it again I would slightly rotate the sensor to the right (maybe 30degrees, when looking towards the front of the car) so that both sensors have a bit more clearance from each other.
So tephra, the wideband should be 3 inches in front of the stock sensor but at a 10:30 o'clock position, passenger side? (considering a USDM LHD car)..
The stock o2 sensor is at a 12 o'clock position right (vertical)?
Old Sep 2, 2009 | 02:15 PM
funks's Avatar
They also sell that socket at autozone..
Old Sep 2, 2009 | 03:59 PM
tephra's Avatar
funks - if your looking towards the front of the car (being under it) the wideband should be at like 0130..
make sense?
Old Sep 3, 2009 | 09:19 AM
funks's Avatar
make sense?
Just to clarify one more time before I start drilling the hole - lol..
So on a USDM-LHD car - if viewing the downpipe from the front (bumper) of the car looking back if then it should be 10:30 position (around 315 degrees) should be pointing up/left towards the passenger side..
Basically, reversed compared to the location shown in the following pics - eq. AMS widemouth downpipe
Old Sep 3, 2009 | 10:26 AM
coevolve's Avatar
that looks good to me...nice pic btw
Old Sep 3, 2009 | 04:05 PM
tephra's Avatar
yeah that will work.
the two after market piece you have will have the 02 sensor coming out at horizontal almost...
next time your under the car just take a look - you will see there is a lot of space above the pipe..
