Methanol injection?
Old Aug 30, 2009 | 02:13 AM
supergengo's Avatar
Agreed, fail-safes which can control boost (or other parameters) would still be needed. However, it would still be a nice option to have a separate, optimized gasoline tune in case you did not want to run meth for a while (like a long road trip).
Old Aug 30, 2009 | 04:44 AM
tephra's Avatar
you don't know about my altmap stuff then do you
Old Aug 31, 2009 | 12:40 AM
supergengo's Avatar
You have alternate maps for the X?
Don't you still require some kind of failsafe mechanism as the trigger for the map to switch?
I'm new to meth/water injection and map-switching, just trying to understand the fundamentals.
Old Aug 31, 2009 | 02:19 AM
tephra's Avatar
Not yet.. but it will be coming.
yes the HFS6 controller can output a signal when failsafe engages, this is seen by the ECU and swithes to safe maps..
Old Aug 31, 2009 | 03:51 PM
Yearlongstorm's Avatar
Ok....wow...I think Ill just upgrade the turbo and cams for now. Thanks to all.
Old Aug 31, 2009 | 08:47 PM
LIGHTSPD's Avatar
I was testing using the knock sensor input using some logic pieces and a relaywith the ground signal from the HSF6 to trip the map to the low octane maps which worked well. However the reset to high output map takes alot longer than desired and the knock learn takes even longer to reset. It was idea but what I would have called a failure. Although another thing learned about the ECU. i am curious what you have in mind I am waiting for one of the members to send me a dissassembly. I don't see why a pointer couldn't be used to redirect based on simple logic. Using a small loop with a jump. More time is needed.
Old Aug 31, 2009 | 09:33 PM
tephra's Avatar
it will be the exact same setup as my TephraMods for CT9A...
with the additional of having a trigger output on when to spray..
Old Sep 2, 2009 | 12:57 PM
ckevox2009's Avatar
meth is definantly the way to go
Old Sep 2, 2009 | 01:11 PM
SilverEvoX's Avatar
Tephra - any idea what the ETA is on the alt maps for the X? Weeks? Months?
Old Sep 10, 2009 | 06:22 PM
NateDaJew's Avatar
Subscribed. Meth is my next mod.
Old Sep 10, 2009 | 07:33 PM
projekX's Avatar
I am using the AQUAMIST HFS-6 on my EVO X, the AQUAMIST HFS-1 on my BMW E90 335i, and the AQUAMIST HFS-1 on my BMW E82 135i. I swear by AQUAMIST
Old Apr 27, 2014 | 12:35 AM
surinder's Avatar
Originally Posted by robh
i run the aquamist system i also run the forge waistgate so my wg pressure is 17 to 18 psi
so my tunner tunned my car to wg pressure frist then has the meth turn on right around the wg pressure and finished tunning the only down side to this that i saw was when the meth turns on the power comes on hard so i tend to have traction issues
if i turn off the meth kit my car made 296 whp at 17 to 18 psi with the meth on i made 395 at 21 psi
i should be headed back to the tunner in a week or so to get tunned at 30 psi so we will see what new numbers i put down this was on a dynodynamics
Hey just to know if its a stock block u gona turn up to 30psi or u done a built?
Old May 8, 2014 | 11:55 AM
GTS4Life's Avatar
Originally Posted by supergengo
I think technically you could have two "pro-tune" maps (1 for meth, 1 for no meth) stored in a Cobb Accessport as a way of accomplishing map-switching.
Is E85 available where you're at? If not I think running dual maps would be best if you run either of them. Having a fail safe sounds like a necessity from what I've seen through my research. I just ended up going with E85 but I live down in San Antonio and we have quite a few stations.
me-var
Oct 25, 2015 02:21 PM
kevness
Oct 2, 2013 04:07 PM
ch1215g
25
Sep 7, 2011 09:32 PM
debashis
Jul 3, 2010 10:10 PM
italianevo88
Sep 10, 2009 12:02 PM
