Boost values logging in Evoscan read higher than reality?
Old Sep 10, 2009 | 09:13 PM
mrfred's Avatar
As long as the boost conversion formula in EvoScan has been adjusted for altitude, EvoScan is going to give very accurate boost values.
Old Sep 10, 2009 | 09:40 PM
LIGHTSPD's Avatar
I havn't looked into it but the differance could be between a guage that is correcting for altitude. I know at my altitude that is about 2 PSI difference between guage pressure and map pressure.
Old Sep 11, 2009 | 04:59 PM
verkion's Avatar
Why can't we just use the Boost = <Data> - Baro Pressure converted to PSI? Actually...I tried to do that and got messed up readings so I'm probably just "calling" the BaroPressure Field incorrectly. Any ideas how to do this?
verkion
Old Sep 11, 2009 | 05:05 PM
mrfred's Avatar
verkion
This couldn't be done with the Evo 7/8/9 because the baro sensor is in the intake track, but since the baro sensor on the Evo 10 is in the ECU, this can be done and makes sense to do. You just gotta work out the correct formula.
Old Sep 11, 2009 | 05:46 PM
tephra's Avatar
Yeah good idea Verkion...
redSLed
Jan 9, 2017 05:22 PM
HornstarBU
Nov 10, 2010 06:22 PM
tipoytm
18
Sep 23, 2009 09:34 AM
Warrtalon
Mar 11, 2008 05:18 PM
