COBB AP & tuned Evo X
Old Sep 13, 2009 | 09:23 AM
lutch's Avatar
I've got an evo x and I've done a lot of mods to it. Turbo, cams and all the other stuff. I've also done EcuTeK flash to the ECU.
I want to use the accessport for monitoring and diagnostics rather than tuning, however if I understand the instructions properly, it says that I've got to install a map first.
When I scroll down the screen I'm getting the option to:
1. install a map
2. troubleshoot ECU codes and errors
3. About COBB accessport.
Where do I go for the monitoring of parameters, 0-60 and quartermile etc?
Old Sep 13, 2009 | 09:53 AM
fmax420's Avatar
1. install a map
I'm pretty sure you have to install a map first.
Old Sep 13, 2009 | 11:06 AM
all4bspinnin's Avatar
the cobb should have a section that says install. Once installed it will copy your cars stock ecu tables... it takes about 20 minutes... once thats done you can load your map.
Once your map is loaded, you will be able to scroll through the main menu and it will have an option with a stopwatch that says performance if you want to check what your car dynos, 1/4 mile, etc. The other selection will say "monitor" if i recall. Thats the option you need to select. You can choose with tables you want to log, plug it into your laptop with accesstuner race software and go at it. All you would need to do is hit start log
Old Sep 13, 2009 | 11:18 AM
evo unknown's Avatar
it saves ur current setting for when u uninstall the AP from the car, it reuploads ur old map, well it is supposed to. it only takes a couple minutes to marry it to the car.
Old Sep 16, 2009 | 09:37 PM
lutch's Avatar
this is what I was afraid of.
so does this mean that I cannot use my current map if I want to use the monitor feature?
If I choose install, the unit would then install a new map which would then superseed my existing map.
s2kvee
Jun 17, 2016 06:20 AM
COBB Tuning
Apr 13, 2016 12:53 PM
RallySport Direct
EvoX 'For Sale' External Engine / Power
Mar 29, 2013 08:26 AM
DrivelineSales
193
Jan 19, 2010 02:29 PM
