P0133 & u0184..??
Old Sep 28, 2009 | 02:59 PM
itoen's Avatar
Help please.. P0133 & U0184..??
Throwing Code P0133 Heated oxygen sensor circuit slow response sensor 1. I have a Cobb dp and an catless test pipe, I put cell fixes on both, does that mean I should remove the dp cell fix?
Also I have a U0184 airbag code, anyone know what that is??
Old Sep 29, 2009 | 02:54 PM
itoen's Avatar
Any help would be much appreciated!!
Old Sep 29, 2009 | 02:56 PM
migs647's Avatar
Far as the P0133... when you say you put CEL fixes on both, you mean on both sensors? It should only be on the rear sensor. The way the system works is the first one reads emissions before cat, and the 2nd reads emissions after cat. Then the two compare results. When the 2nd one is moved further away from the emissions it gets a "lighter" reading. If both are moved away then both would get lighter readings and the difference wouldn't be enough to make the fix work. I might be misreading what you said, sorry if so.
Old Sep 30, 2009 | 02:25 PM
itoen's Avatar
Nope that's what I thought, I will remove the first cel fix thanks alot!
prattyjunior
Dec 7, 2015 05:30 AM
Dawid5surowiec
Aug 2, 2013 06:31 PM
evo IX king
Feb 10, 2011 02:22 PM
ZWingerRyRy
21
Feb 9, 2011 09:07 AM
shyong
13
Sep 30, 2009 07:21 PM
