car going into limp mode
Old Oct 13, 2009 | 09:24 PM
TTP Engineering's Avatar
Originally Posted by GST Motorsports
They work 100%. Operator error or incorrect def if they aren't working.
I've tested it many times on many 10's, including one holding 30psi across to 8000 rpm.
it's actually really easy to test. Increase the airflow/torque maps until it triggers the CELS and limp mode. Then turn off the DTC's with tephras defs, keep the airflow/torque maps the same (that trip the limp mode) and run the car again, like magic, no more limp mode.
- Bryan
The proper figures are showing up in the respective places so the code appears correct.
Is the code the same from 0015-0020?
Old Oct 13, 2009 | 09:27 PM
GST Motorsports's Avatar
Which code are you popping even after doing the DTC disable?
Old Oct 14, 2009 | 04:22 PM
1235 on the list of codes "able to be disabled"
0026>>>>>0xFFFF = code still
Old Oct 14, 2009 | 04:33 PM
tephra's Avatar
can u email the rom in question?
Old Oct 14, 2009 | 08:16 PM
Got it worked out. Evidently there were only three addresses released at first and the last two came later. Have all five now. Will test again.
Old Oct 14, 2009 | 08:19 PM
tephra's Avatar
yup no worries !
jayson2k2
Jun 10, 2023 03:01 AM
jman49127
Lancer Troubleshooting
Feb 17, 2017 07:22 AM
MadBoost23
Lancer Engine Management / Tuning Forums
Jun 10, 2015 11:57 PM
seymour86
Nov 6, 2013 04:52 PM
elpoole
45
Jul 31, 2008 08:42 AM
