(PICS) KNOCK when your LTFT's lean out...check it out
Old Oct 14, 2009 | 06:50 AM
  #31
tephra's Avatar
all of a sudden I started getting upto 16KS in cruise...
reduced timing, flashed to stock.. nothing helped.
well today for the first time in 1 month I got a log without knock higher than 3KS... very weird...
Old Oct 14, 2009 | 07:38 AM
  #32
crcain's Avatar
Presumably the knock was false?
Have we seen any instances of false knock on X's? Of course their is the normal bits of lift off knock and such. But I mean something more persistent and mechanical.
Old Oct 14, 2009 | 10:46 AM
  #33
Clipse3GT's Avatar
I did a compression test on all four cylinders after driving for 30 minutes. The engine was hot. So the compression was all 4 cylinders at 145PSI. So it looks like compression is okay. I swapped the relay with the green and everything is normal again. I also did a ECU reset. cruise LTFT are about -0.1 and on decel/idle about -6.2. The car actually now richens to 10's (as low as the AEM wideband reads) So everything looks dandy now. No knock. I attached the last two logs I did both 30 min sessions. Everything looks good, except when I get into boost it dips into 10's and then slowly goes to 12's then 11's for AFR. This is the most messed up **** I have ever seen. I switched relays before everything stayed the same, now everything is back to normal. One thing I noticed is I update the COBB AP to some new BETA that came out a day or two ago. So I don't know if it wasnt a software issue.
Old Oct 14, 2009 | 10:53 AM
  #34
Clipse3GT's Avatar
1st 30min log right after reset
http://www.mediafire.com/file/vynnw3...4_10.27.27.csv
2nd 30 min log after the car sat around for 2 hours
http://www.mediafire.com/file/mnmnkl...4_12.30.29.csv
Clipse3GT
44
Jan 29, 2022 09:54 PM
Clipse3GT
22
Oct 19, 2010 09:21 AM
Clipse3GT
Apr 14, 2010 09:02 AM
Clipse3GT
10
Nov 4, 2009 09:50 PM
Clipse3GT
15
Jun 11, 2009 01:41 AM
