Help, Cobb Stage 2 breaking up at high RPM
Old Nov 6, 2009 | 06:04 AM
Ruff Ryda's Avatar
I'm running Cobb HKS 93 oct stage 2 map. My mods are just a panel filter, UICP, pulled the pill (I tried putting it back in because I was slightly overboosting, but I had the same results.) and AP.
I'm getting a lot of breakup that starts at about 5500rpm at WOT. I'm thinking plugs are possibly getting weak, but I just don't know. I'm also getting tons of black smoke during the breakup, so I don't know if it is from overfueling or misfire.
Any help would be great. Thanks.
Old Nov 6, 2009 | 06:10 AM
Sharkbite2000's Avatar
probably going super rich and turning off the spark. Pull out the plugs and check the way they look see if it's all black.
Old Nov 6, 2009 | 06:20 AM
Ruff Ryda's Avatar
That's what I was thinking, but I'm somewhat of a rookie when it comes to this stuff. I'll try to do that in the morning. Thanks!
Old Nov 6, 2009 | 10:18 AM
cool_g_83's Avatar
Are you running a turboback exhaust as per the instructions for a stage 2 map?
Old Nov 6, 2009 | 10:26 AM
jeangtd's Avatar
Originally Posted by cool_g_83
are you running a turboback exhaust as per the instructions for a stage 2 map?
+2
Old Nov 6, 2009 | 05:52 PM
mrMTB's Avatar
Yeah, looks as if you should have read the stage II requirements a little more closely... Put the pill back in, and reflash to HKS Stage I.
Old Nov 6, 2009 | 11:12 PM
raytrix's Avatar
A minimum of a catback + test pipe is required for a stage 2. You don't necessarily need a DP upgrade as the stock one already flows very well.
Old Nov 7, 2009 | 05:15 AM
Ruff Ryda's Avatar
For all that don't know, Stage 2 does not require the exhaust system(per Hollywood).
I have read the instructions and am fully aware of what cobb states is required.
It has been verified by several other people and tuners that the stage 2 is safer without the exhaust and not absolutly needed.
Old Nov 7, 2009 | 06:46 AM
RobY's Avatar
Well, some people are obviously having problems running a stage II map on a stage I equipped car. So maybe there is something to COBB's recommendation...
Old Nov 7, 2009 | 06:50 AM
Ruff Ryda's Avatar
lol Maybe. Do you have any history with the AP?
Old Nov 7, 2009 | 08:35 AM
LaXGSR's Avatar
Why don't you call Cobb directly? There has to be a reason they have a stage 1 versus stage 2 map right? It "might" be ok for "some" cars to run stage 2 without an exhaust, but I would guess that in general, it's safer and better to run the stage 1 map. Try stage 1 and see how it runs.
Old Nov 7, 2009 | 09:12 AM
Ruff Ryda's Avatar
Getting ready to flash stage 1 here in a few.
Old Nov 7, 2009 | 09:59 AM
lowkey's Avatar
Registered User
Stage 1 - Intended for an otherwise stock 2008 Mitsubishi EVO X GSR vehicle with a stock or cat-back exhaust
Stage 2 - Intended for an otherwise stock 2008 Mitsubishi EVO GSR vehicle with full turbo back exhaust system
Which part of “full turbo back” don’t you understand?
Old Nov 7, 2009 | 10:55 AM
Ruff Ryda's Avatar
Edited.
I am very aware of what cobb claims that you need to run stage 2.
This is the type of response i was looking for.
Originally Posted by hollywood_X
Also when running stage 2 without the "Requested" modifications that Cobb lists you wont get the full benefits from the tune.
You gave a lot of down low grunt but in the upper rpm's at higher gears the exhaust backpressure will start effecting you.
Getting a good cat back will solve the power loss and studder that you are experiencing.
Old Nov 7, 2009 | 11:20 AM
EVOXMAINE's Avatar
mine does it with just stage 1 it doesn't have anything to do with stages or turbo-back / stock. It must just still be getting far to much fuel up top... wish I could get rid of this so I can haul *** all the way to redline!!!
