I want to log boost please explain?
Old Nov 25, 2009 | 02:09 PM
jrsimon27's Avatar
i read a lot of folks are logging boost using evoscan v2.6 iam using this as well but i cant figure it out how to log boost when making logs could someone please explain me step by step on how to do this?
thanks
Old Nov 25, 2009 | 02:13 PM
Hiboost's Avatar
Search or Stickies would have found your solution:
https://www.evolutionm.net/forums/ev...lustrated.html
Basically get EvoScan 2.7 and you can log boost just fine. Some older methods for logging boost were capped at 22 psi or so which has now been overcome with direct logging of the 3 bar map sensor in EvoScan via enabling Mode23.
Old Nov 25, 2009 | 02:27 PM
jrsimon27's Avatar
thanks hiboost i did read through it but dont quit understand it where can i download evoscan v2.7?
Old Nov 25, 2009 | 02:47 PM
Hiboost's Avatar
When you register the product you should have gotten a link to download the latest version. Place a trouble ticket with them at their website and they will get back to you within a couple days with a link for you.
Old Nov 25, 2009 | 05:42 PM
jrsimon27's Avatar
i tried to follow the instrucions from the link but the thing is that the internal id from my ecu is 52690021 which it isnt in the list so thats what has me stuck i sent a ticket to hamish i hope he send me a link to download v2.7
Old Nov 26, 2009 | 10:42 AM
stokEd's Avatar
http://www.limitless.co.nz/evoscan/EvoScanv2.7beta5.zip
Old Nov 27, 2009 | 01:42 PM
jrsimon27's Avatar
thanks buddy
Old Nov 27, 2009 | 10:11 PM
stokEd's Avatar
PM tephra or SiC for the XML code you need to setup Mode23 on your ROM. Not sure if 52690021 maybe inherits from 52690019...
Edik_898_
Nov 28, 2016 02:02 PM
evo jason
Jan 7, 2012 04:25 AM
08GsrX
Aug 29, 2011 01:34 PM
ch1215g
16
Feb 20, 2011 10:46 AM
jamie_v1
Oct 11, 2008 03:03 PM
