Safe to install FMIC and LICP?
My car is currently tuned for the setup on my car. I have a FMIC and LICP being delivered tomorrow. Is it safe to install these without a retune? I realize it's ideal to re-tune when you change your setup, but it will be another 6-8 weeks before I will be getting the rest of the parts for my build... I will have a re-tune scheduled then. So... simple question, can I install the lower piping and FMIC without negative affects on my engine or performance?
I do have a Cobb AP... should I just monitor knock after the install to make sure that there aren't any huge counts during open throttle? Is there anything else I should pay special attention to after the install?
It's questionable whether an fmic helps at all with the stock turbo. A drop-in, exhaust, and a good tune seems to be all that you need. Upgrade the fueling for E85 and do everything else with an uprated turbo.
I don't necessarily expect gains from putting the parts on. That's why I asked if it would hurt performance. Injectors, upgraded turbo, some new plugs, and a 3port BCS are the other upgrades planned for the winter months... those will be installed by CBRD along w/ a tune.
