O2 simulator
Old Dec 15, 2009 | 04:17 AM
boy36's Avatar
O2 simulator
Hi
I mount Testpipe ,Downpipe and AMS O2 Sensor spacer.Now i got thre times CEL P-0139 - Oxygen Sensor Circuit Slow Response.
Because I do not want to every week deleted code I want to know if anybody try this :O2 simulator
http://www.o2simulator.com/
Old Dec 15, 2009 | 10:18 AM
Clipse3GT's Avatar
It means that your o2 sensor is too far away from the exhaust flow.
Old Dec 15, 2009 | 10:51 AM
rogue's Avatar
You should use the AMS spacer, possibly one of the larger holes...
I think it comes with three sizes.
Old Dec 15, 2009 | 12:33 PM
boy36's Avatar
Yes AMS spacer have three holes and I m using the large one.
Old Dec 15, 2009 | 12:56 PM
Clipse3GT's Avatar
Dont use a spacer at all did u try that?
Old Dec 16, 2009 | 08:07 PM
criptballer's Avatar
any thoughts on P0140 code ? i keep getting that no matter what i do. tried disabling it with a code on ecuflash, didn't work. tried running it like normal didn't work. tried buying a spacer didn't work. nothing seems to work for this damn code. my next step is to hook it up on the other bung that the UR test pipe comes with which i believe is for a wideband, but who knows maybe it will work....
Old Dec 16, 2009 | 08:20 PM
aftershock141's Avatar
Do you have it closer or further away from the downpipe right now? It should be as far away as possible.
Old Dec 16, 2009 | 08:51 PM
its got an extra bung extender on it so its is about 4 to 5 inches away from the downpipe
Old Dec 16, 2009 | 09:00 PM
xPRimNT's Avatar
And the code was 0140 with the extender?
If so, put a piece of steel wool in the extender. It should limit exhaust flow even further.
Old Dec 17, 2009 | 08:03 PM
but the code says "not detected" wouldn't that make it worse? i'm going to try it without the extender and with the steel wool. we'll see i guess.
Old Dec 17, 2009 | 08:18 PM
xPRimNT's Avatar
Oh, good call. I thought this was a 0420 even though I specifically typed out 0140.
Are you sure the O2 sensor is intact and plugged in?
Old Dec 17, 2009 | 09:58 PM
yup. pretty damn sure haha. hopefully the wool without the extender works, i really want it to work....
Old Dec 17, 2009 | 10:21 PM
xPRimNT's Avatar
I received 0140 when my sensor is unplugged. Now that I have my wideband running through the rear O2 circuitry, I get an 0139 (slow circuit response). The "disable" options in ECUFlash did not take away either of these unfortunately.
I'd love a fix, whether it be as mentioned in the OP, or some other ECU method.
Old Dec 18, 2009 | 02:38 PM
i'll let you know if some steel wool worked for me.
Old Dec 24, 2009 | 09:57 AM
steel wool fixed my problem!
turbotaloon95
Aug 9, 2016 07:51 AM
JRally
May 25, 2016 10:18 AM
stokEd
51
Oct 14, 2015 06:44 PM
Bitnode
Dec 14, 2012 11:23 AM
hjp918
Jun 4, 2012 11:10 AM
