F.....g Idle
Old Dec 20, 2009 | 09:21 PM
DG Motors's Avatar
Originally Posted by lousEVOxmr
i was thinking of actully , coming and see you guys pretty soon...
im getting my intercooler next week some time ,
and mybe a little change in the stock turbo lol.... who know maybe cams ,
im undisided at this time
thanks PETE for answer this thread
at first i had the big bang problem , i figered it was over boosting bc of the temp, out side
but no i started have the idle crazyness like if i would have cams....... the warmer the car gets the bigger the stage cams i have lol... j/k
ohh answer the question Novaspyder isnt getting any problems and pat 031 well i dont really talk to him much so...
i have a check engine light so im ganna pull the codes out tmw as soon as shops open up tmw ...
and no i dont not have the 2.0 cable yet :S
Sounds like a plan. I am sorry for the minor issues you are encountering. Give me a call Tomorrow and let me know what the codes are.
Look forward to working further with you on the car, if you have any other questions on parts, etc let me know!
Talk to you soon!
Old Dec 21, 2009 | 02:09 AM
DirtyCookieX's Avatar
https://www.evolutionm.net/forums/ev...s-do-asap.html
I'm assuming you've check this?
Old Dec 21, 2009 | 05:15 AM
lousEVOxmr's Avatar
ya i have ive pulled out every dump little line and ziptied it to hell and back lol...
if i see one more ziptie im ganna snap .!!! lol
Old Dec 21, 2009 | 09:21 AM
lousEVOxmr's Avatar
so i pulled out the code ....... im not really happy about that ........
hopefully it wont cost me pistons ..... ahhhh...
the code P0303
miss fire cyl,3
...................im changing my spark plug tonight when i get them
Old Dec 21, 2009 | 09:44 AM
DG Motors's Avatar
the code P0303
miss fire cyl,3
Your idle is causing a mis-fire code. It is most likely something simple that you are over looking. Like I said, pull the plugs, check them, re-gap to .024 and give that a shot. Have you boost leak tested the car?
Which upper IC pipe do you have again? A few cars have ripped the coupler that connects the upper IC pipe to the turbo outlet and you can not see the rip until you take the pipe off of the car.
Old Dec 21, 2009 | 10:40 AM
lousEVOxmr's Avatar
ive double checked , tock everything off and cleaned and checked with no luck, injen upper
Old Dec 21, 2009 | 03:32 PM
ETS Michael's Avatar
What intake is on the car? Do you have a shield on the intake?
Old Dec 21, 2009 | 03:47 PM
COBB Tuning's Avatar
Did you check the fuel pump relay? That could part of the issue if your pump relay is going bad. "All of a sudden" problems are generally some form of part failure if no other changes have been made.
Old Dec 21, 2009 | 03:57 PM
lousEVOxmr's Avatar
yes i have the ams , with shield
Old Dec 22, 2009 | 02:27 AM
xhomm02's Avatar
Originally Posted by DirtyCookieX
Yes I checked :-(
Old Dec 22, 2009 | 02:28 AM
xhomm02's Avatar
Not this problem - the idle hesitates no metter whether runnig gas or LPG (both using independent fuel rails and injectors)
Old Dec 22, 2009 | 04:30 AM
Chef-j's Avatar
the code P0303
miss fire cyl,3
I wouldn't worry that yet. It might be simple plug issue or fuel issue. Try clear that code and see if that throws again.
Old Dec 22, 2009 | 04:49 AM
Chef-j's Avatar
Check stock cat core. Those thing can melt down and could cause idle issue. But sounds like you've done pretty much. Idk if cobb AP can fully control stock ECU at idle (I'm new to evo). if its not, I would start make a plan to take it to local tuner, see if tuner can play with stock ECU.
Old Dec 22, 2009 | 08:49 AM
DG Motors's Avatar
This problem just occurred, I think It is safe to say on my part that it is not tune related.
Old Dec 22, 2009 | 09:38 AM
Silentbob812's Avatar
yea, a lot of evos with open element intakes have idling problems..... It could be since you're getting into the colder time, that you're using your heater/defroster more, and the fan is blowing into the intake. Even with a tune, that'll cause your engine to idle funny.
I also have AMS intake with a sheild, and still have that issue. I just dont run the AC/heat when I dont need it.... and then accept the silly idle issue when it does it.
