ECU tune + upgraded solenoid??
Old Jan 18, 2010 | 04:25 AM
vrrroommm's Avatar
Forgive me for the newbie question, but I've been reading across the diff. forums on this. Everybody seems to agree that EBC (like Blitz, HKS EVC, etc.) will not do a better job than ECU controlled boost (i.e. tune). Is this true?
I've also read, and been told by couple of shops, that the stock boost solenoid will not be able to handle the extra boost, and are not that 'realiable'/consistent.
What solutions are there if you don't want to buy the EBC for the upgraded solenoid, and need to buy it before you do an ECU tune?
One example I found is this Perrin solenoid:
http://www.perrinperformance.com/sha.../862_large.jpg
Is this reasoning correct? If it is, any review on the Perrin EBCS from the experts/pro builders here? Any advise would be very appreciated.
Old Jan 18, 2010 | 05:22 AM
tephra's Avatar
stock setup wont be able to hold a decent amount of boost UNLESS you either replace the pill OR use a new solenoid.
HOWEVER for a minimal mod car its probably not necessary since you can basically make the same power (high boost + low timing VS lower boost + high timing)
Personally I like the flexability of the 3port, it gives very fine grain control over boost...
Old Jan 18, 2010 | 11:52 PM
vrrroommm's Avatar
G'day Tephra! (Heheh.. lived in Sydney for a couple of years)..
Thanks for the input. So I do need to replace to the 3port in the near future... any other options other than the Perrin that you know of?
Cheers!
Old Jan 19, 2010 | 12:33 AM
tephra's Avatar
lol
tactrix make a very nice P&P 3port
Old Jan 19, 2010 | 07:10 AM
mlomker's Avatar
GrimmSpeed has pnp, a lot of guys modify a GM unit to work. The GrimmSpeed is a nice looking piece compared to the Perrin.
Old Jan 19, 2010 | 08:09 AM
MicMcKee's Avatar
I ran the GrimmSPeed 3 port on my Subie, that's what I plan on getting for my X as well
Old Jan 19, 2010 | 11:51 AM
Whitewind's Avatar
Go to the other forum and look under sale section just posted today grimmSPeed 3 port. $100 shipped.
Old Jan 20, 2010 | 10:50 AM
stokEd's Avatar
The GM is now PnP. Harnesses can be found here: http://www.spoolinup.com/diy.html
Old Jan 20, 2010 | 03:23 PM
GrimmSpeed's Avatar
Hey guys thanks for the support! The bracket fits perfectly and its plug and play!
Old Jan 21, 2010 | 09:16 PM
gunzo's Avatar
Teph, its your car ..
without the mods you mention, you can hold reasonable boost 1.7bar to 1.4bar at redline ..
I agree the duty cycles will be at 100% relatively earlier without doing the things you mentioned
hawaiian_evo
50
Nov 26, 2013 08:52 PM
PERRIN_JOHN
Jul 29, 2010 09:01 PM
PERRIN_JOHN
Nov 27, 2009 10:38 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
PERRIN_JOHN
Mar 13, 2009 11:38 AM
