Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
Got mine working on my 5 at last only can't get the Start stop function to work the logcfg.out file says there something wrong with the below but not sure what
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
Also I'd like it to start logging at 2000rpm and stop when it goes below that
any ideas?
or do I need the RPM para before it as well
action = start
action = stop
any ideas?
paramid=0x21
scalingrpn=x,31.25,*
conditionrpn = RPM,2500,>
action = start
conditionrpn = RPM,2000,<
action = stop
need to have the paraname=RPM part befor the start stop function
Got a new one though to log WOT, starts at 96% TPS and stops less than 2500rpm
Ok so i have read this fourm and still can't figure this out. Please help me!!! I got all of my adress from https://www.evolutionm.net/forums/09...iles-here.html so im going to assume they are correct
I am getting an .out File but i cant open it with any thing so i have no idea if it is even data logging. So i'm having troubel with logging in general, once i get that figured out i belive ill be able to figure out the start/stop function, it wont let me upload the logcfg.out file
or post it on here
I have tryed to put it on here it wont for some reason, when i get home on my laptop i'll copy what it tales me and put it into a new txt doc and post it up.
Last edited by Conway_160; May 8, 2012 at 02:12 PM. Reason: found my logcfg out file
That's pretty screwy. It looks fine from the text file you uploaded... but the OP2.0 is *****ing.
Only two things come to mind...
(1) Some weird line-feed issue with your text file (DOS vs. non-DOS). Not likely - I don't think the OP2.0 gives a hoot.
(2) Really old firmware on the OP2.0 that doesn't understand "mrmacan" format.
I'm putting my money on (2). You could try the firmware update trick from EcuFlash. Look it up, but from memory, you run up a recent EcuFlash, connect the OP2.0, then select "Licensing" from the topbar menu. I don't think you actually have to DO anything in that option... just selecting it kicks off a firmware update to the OP2.0.
For what it's worth, I used EcuFlash 1.43.3150 to do my OP2.0 firmware update. It's a bit old, but the firmware it delivered to the Tactrix box works fine for logging.
Rich
Rich
How does one get the correct time and dates for the log files?
I've also recently realised that I cannot use the Tactrix Open Port cable to read or flash a car if the micro SD card is left in.
I'm not sure if I could before either
I've always been able to flash with SD in too. (maybe I got the latest beta firmware when I got it, but that was right after it came out)
There is no battery in the OP2.0, so it will lose time/date each power down. I suggested that they use the most recent date any file was saved and increment from there but it was not implemented to my knowledge (at least you would have *some* reference then).
There is some funky way to get it to remember something along the lines of never removing power and plugging your laptop into it. I've seen newer dates in my files.... but it doesn't help that (I think) the power is cut to it after 10 minutes of ignition off.
