Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
Old May 4, 2011 | 02:28 PM
  #151
neilm's Avatar
hi
will this work on a evo 7
Old May 5, 2011 | 07:24 AM
  #152
fostytou's Avatar
EvoM Community Team
Originally Posted by neilm
hi
It should work in standard mode, but will not work in mode23.
Old Oct 6, 2011 | 06:44 AM
  #153
gwigga's Avatar
Ok heres one... on an Evo 5
Copied the logcfg.txt over to SD card, went for a drive and all I get is the green flashing light no red, and the only file I get is logcfg.out
Old Oct 6, 2011 | 09:28 AM
  #154
fostytou's Avatar
EvoM Community Team
Are you using mode23 or MUT?
Old Oct 7, 2011 | 06:35 AM
  #155
gwigga's Avatar
My Logcfg.txt is set for MUTII
Old Oct 7, 2011 | 07:57 AM
  #156
fostytou's Avatar
EvoM Community Team
What logcfg.txt did you copy? Did you set a start/stop parameter? Have you read the documentation? What have you tried to fix it? We need much more info to know whats going on here.
Old Oct 10, 2011 | 01:47 AM
  #157
gwigga's Avatar
Turns out that we need to short pins 1 & 4 on the obd connector to enable logging on the older Evo's, as its not done on the OP2
Old Feb 21, 2012 | 05:45 PM
  #158
momostallion's Avatar
Exclamation size matters
please note, i was unable to make an 8 GB class 10 micro sd card work with openport 2.0. the 8 GB card was formatted as fat 32. i called tactrix and they suggested the 8 GB card was the issue.
I ordered a 2 GB card on amazon for $5 and it work instantly as soon as i copied the logcfg.txt to it.
it might be worth updating the original post with this info to save people the headache of trying to figure out whats wrong, especially now that 8 GB micro sd cards are "small" these days.
mo
Old Feb 21, 2012 | 06:18 PM
  #159
tephra's Avatar
my 8GB card is ok.. pretty sure its fat32 as well (otherwise I wouldn't get 8GB usable right?)
not sure what class though, SDHC whatever
Old Feb 21, 2012 | 06:26 PM
  #160
that sucks for me! i tried fat 32 and ntfs file systems. i was unable to make mine work. after 3 days of trying multiple variations of logcfg.txt files i gave up and called tactrix. they make it seem like that's a common problem.
sure enough, the 2 gb drive arrived in the mail today so i throw a logcfg.txt on it and TA-DA! it works.
the one that would not work for me was a PNY brand 8 gb class 10 SDHC card.
Old Apr 17, 2012 | 05:41 AM
  #161
revol's Avatar
hi .. ive got 2 question..
1. can i use the logout. file posted here for lancer 4b11 na JDM 2009?
2. my sd card are now stuck inside tactrix 2.0..hahaha...unable to take it out...
can i still log with laptop when the sd card is inserted..
sorry for the noob question..thnks..
Old Apr 22, 2012 | 12:57 PM
  #162
gsrony's Avatar
Having problems logging with a 2011 GSR, values in evoscan look correct but I'm only getting accurate psig readings everything else is off. Using posted cfg does this not work for newer models?
Old Apr 22, 2012 | 02:56 PM
  #163
probably not. just check your logcfg file against the addresses you have selected in evoscan. make sure to check it its 2 byte.
Old Apr 23, 2012 | 06:52 AM
  #164
gsrony's Avatar
from log:
paramname=RPM
paramid=0x808746
databits=16
scalingrpn=x,3.90625,*
evoscan:
request id: 23808746
eval: 3.90625*x
response bytes: 2
it displays correctly in evoscan... not sure what I'm doing wrong?
Old Apr 25, 2012 | 01:38 AM
  #165
gwigga's Avatar
Got mine working on my 5 at last only can't get the Start stop function to work the logcfg.out file says there something wrong with the below but not sure what
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
Also I'd like it to start logging at 2000rpm and stop when it goes below that
any ideas?
or do I need the RPM para before it as well
