Got some knock, should I adjust timing or fuel
Old Feb 27, 2010 | 10:25 PM
  #31
SiC's Avatar
SiC
Originally Posted by smanders
I thought the EBC was supposed to be better, but I'm having a hard time getting the boost to be smooth. I haven't given up on the EBC yet though. I'll keep you posted.
In general when you mention an EBC I think of a standalone system like an HKS EVC but what you have is what is normally reffered to as a 3 port solenoid that plugs into the factory harness. Since what you have is controlled by the factory ECU, it should do pretty good in controlling boost unless the reaction speed of the solenoid is slow.
Are you sure it's plugged into the correct solenoid connector and the lines are correct?
Old Feb 27, 2010 | 10:34 PM
  #32
smanders's Avatar
I believe so, I'll double check the install. When i say EBC I think of 3 ports and standalone boost controllers. Just so we're clear, I'm using the stock ECU to control my GrimmSpeed 3 port. I think I'll have it dialed in soon. I haven't been able to dedicate time to it over the last few days. Maybe tomorrow.
I'll keep this thread up to date.
Old Feb 27, 2010 | 11:39 PM
  #33
Chris Moore's Avatar
Originally Posted by Whitewind
3 port with stock ecu control is best way man. Easy tune for. Nothing wrong with ebc but not for me when ecu is safer and better.
I run ecu controlled boost on my car, but keep in mind that for some people it is not at all easy to tune. Some people like the ease of set up and adjustment of an EBC or MBC.
Old Feb 28, 2010 | 12:34 PM
  #34
Whitewind's Avatar
Well some people should not breath but they do. It is WAY safer to run it through your ecu. Now if you got 3 port and using your ecu good deal. The ecu on x is very good.
Old Mar 14, 2010 | 08:47 AM
  #35
smanders's Avatar
The saga continues below. Since the topic is evolving, I need to start a new thread. OBTW, its on the "other" forum that apparently is not allow to be cross-linked (EvoXForums)
http://www.(evoxforums dot com)/forums/showthread.php?p=391434
3VOLUTIONIST
Dec 10, 2016 07:20 PM
sharkm87
Apr 7, 2011 03:45 AM
tephra
Oct 31, 2010 10:32 PM
UT_EvoX
12
Jan 3, 2010 01:55 PM
Raceghost
Sep 14, 2009 05:46 AM
