Omni 4 bar scaling??
Old Mar 31, 2010 | 10:19 AM
murlo26's Avatar
I have seen people tuning with ECUflash use the 4 bar MAP sensor on the X's but I didn't see any tables for them when i was looking with a buddy who knows the program, maybe his didn't have the definitions.
Is this readily available? I need to scale my new sensor.
Please help, thanks guys.
Also...sorry if this has been covered, i haven't seen it and i frequent the forums.
Old Mar 31, 2010 | 01:05 PM
mlomker's Avatar
GST and DG Motors have both mentioned doing them in threads. Hopefully Bryan will reply.
I also have one that I could install.
Old Mar 31, 2010 | 01:11 PM
murlo26's Avatar
^Yea those were two that I was thinking of.
Someone has to have something.
Old Apr 2, 2010 | 12:45 AM
tephra's Avatar
i havn't looked into this yet...
it can be done - but I would need to take a look to find out what needs to be changed...
Old Apr 2, 2010 | 01:11 AM
HR2L's Avatar
Hey Murlo, what 4 Bar MAP sensor do you plan to run on your X? Have been thinking about going with one, but am also curious who and if there are tables available VIA EcuFlash to tune with it.
LMK!
Old Apr 2, 2010 | 01:17 AM
tephra's Avatar
Omni 7 bar FTW :P
But yeah we have to find the tables... shouldn't be too hard, just someones gotta do it...
i guess me :| :P
Old Apr 2, 2010 | 01:18 AM
HR2L's Avatar
Originally Posted by tephra
Omni 7 bar FTW :P
i guess me :| :P
I was thinking about an OMNI 4 bar, as a 7 bar might be a bit of an overkill, No Tephra? But I guess for an additional $30 might be worth it?
Would be killer if you could find the tables (if they aren't already known).
Old Apr 2, 2010 | 01:23 AM
tephra's Avatar
well thats the nice thing about the OMNI's (as far as I remember) you can go pretty high and not really sacrifice accuracy
anyone done any homework on whats plug and play (well plug'n'tune)???
Old Apr 2, 2010 | 05:35 AM
Hiboost's Avatar
I saw this about 4 Bar Omni sensors which will raise the limits from 32 psi to about 44 psi according to MRFred:
https://www.evolutionm.net/forums/ec...evo-8-9-a.html
Perhaps that can be used as a basis to determine what changes are needed for the Evo X rom.
Old Apr 2, 2010 | 07:10 AM
murlo26's Avatar
I already have bought the 4 bar OMNI one.
Just need a way to scale it now
A good donation is in line if you can find this Tephra! It looks like a few people want this.
Let me know! Thanks Buddy.
Old Apr 2, 2010 | 08:50 AM
mlomker's Avatar
Ditto on both counts.
I bought mine from TTP but I assume they only install them on the 8/9. We know the table exists because someone on the other forum told us that the Cobb AP can adjust it.
Old Apr 2, 2010 | 11:04 AM
GST Motorsports's Avatar
Cobb does not have the tables necessary AFAIK. They have two related tables but not some other familar ones, but I could be wrong.
Tephra, the Omnipower MAP sensors are plug and play, just need to find the correct tables.
I would imagine it's a bit more in-depth code wise then the 8/9 since it looks like the Evo 10 uses the MAP sensor for fueling computations. I remember Mrfred mentioning this awhile back when he went code diving...
- Bryan
tephra
70
Jul 11, 2024 12:59 AM
Raptord
Sep 12, 2021 03:15 PM
cplillges
Apr 21, 2017 12:51 PM
fayez-winner
Feb 20, 2017 02:04 PM
boosted91t
Apr 15, 2016 07:48 AM
