High idling RPM problem
Old Apr 13, 2010 | 07:48 AM
jackfrog's Avatar
some update.
i installed stage one 93 to my MR, took out drop in filter, put the stock one back, no more high idling issue, just a little bit louder than before. im gonna run stage two tomorrow and see what happen.
Old Apr 13, 2010 | 09:34 AM
5ynth3t1c's Avatar
My MR idles high when in drive and stopped at a light. 1500rpm. I uninstalled the AP and it doesnt do it anymore. It started when I upgraded to the v1.06 map. I tried it with the HKS filter map and then put the OEM filter in and changed maps and it still reved high.
Old Apr 13, 2010 | 10:25 AM
jackfrog's Avatar
i put stock filter back, running stage one 93, when stop at a light, it rev to 1500 but couple seconds down to 800. it doesnt stay high anymore but definitely not running smooth enough. the rev just kinda weird. im gonna uninstall it and wait for new update from cobb.
Old Apr 13, 2010 | 12:40 PM
derekste's Avatar
I made a post about this almost a year ago. My story:
08 GSR. Every now and then, my car would get into "high rpm" mode where it would not idle below 2000 RPM (usually it was 2000 RPM, but sometimes it was 1750 or 1500). When in this mode, it would dip down, say, to 1500 when at 2000 as I stopped, but as I sat there it shot right back up! Two things seemed to cause it: really flogging on the car, or partial throttle (<30%) during spool in 5th gear. It seemed to happen A LOT this winter, but hasn't happened in close to two months now that the weather has been getting nicer. Oh yeah, no CEL.
I did a log once(it was hard to reproduce. to the OP: does this happen constantly, or erratically?), and the only thing I noticed is that Throttle Position seemed to be higher (around 14% vs 8% normally) when this occurred, so I attributed it to some sort of failure in the DBW system (bad TPS? bad pedal sensor?). Never really figured this one out, but didn't look too hard. Perhaps it is related?
Old Apr 13, 2010 | 02:12 PM
SilverEvoX's Avatar
Sounds like what happens after you throw a p1235 (overboost code) the car idles between 1500-2000rpm. I know quite a few cars throwing that with the Cobb stage 2
Old Apr 13, 2010 | 02:27 PM
jackfrog's Avatar
i think the problem on GSR is different from MR, i read a lot about this recently, and theres a 20+ pages thread about this, search MAF bad you might see something worth to read, im sure you can get your answer there. in your case i would say check the MAF and your intake or drop in filter might be bad for MAF sensor. a lot of ppl had this issue and they found MAF was bad. what code did you get?
on MR a lot of ppl got high idling at 1400, 1500rpm and wont go up like 2000rpm on gsr, this only happened when they updated 1.06 map. so what they do is either using old 1.04 map or back to stock map, and wait for new update from cobb.
Old Apr 14, 2010 | 10:18 AM
derekste's Avatar
that's the thing... there was no cel/code! restart the car and it went away.
Old Apr 15, 2010 | 02:34 AM
xhomm02's Avatar
I looked into the Cobb maps and it looks like there is a mistake - in maps 1.04 and below the idle RPM were correct (about 700), but with new release of 1.06 there is idling in gear set to 1398 RPM.
You can downgrade to 1.04 version or manually change the map setting for idle in the 1.04 version.
Old Apr 15, 2010 | 04:41 AM
jackfrog's Avatar
yea someone sent me the old 1.04 and im using it now. works fine. thanks
Old Apr 15, 2010 | 01:59 PM
DarwinX's Avatar
Has anyone notified the people at Cobb about this?
Old Apr 15, 2010 | 05:23 PM
jackfrog's Avatar
theres a thread about this on cobb's forum but i believe they are still working on it...
Old Apr 21, 2010 | 06:16 PM
Optiblue's Avatar
http://www.cobbforums.com/forums/sho...-MR-Idle-Issue
Cobb has a temp fix for us
Old Apr 22, 2010 | 07:19 AM
jackfrog's Avatar
Originally Posted by Optiblue
u kno i should use the temp fix map or the old 1.04?
Old Apr 23, 2010 | 12:00 PM
Optiblue's Avatar
I emailed them and they sent me a 1.07 test 93 stage 2 hkspf map. For the most part, the idle goes down at a stop, BUT it's still maybe 100-200rpm higher than 1.04. Also, as you slowly come to a stop, from what I can tell as the clutches releases, RPMs move upwards towards 1400 momentarily, but will continue to drop as you come to a complete stop.
Something is still a bit buggy, but I will definately keep this map around. With these "issues" it somehow makes the car very quick in the city esp. around sweeper corners. It might be that it's inducing more throttle (using more gas) like a throttle controller, but it makes the car more fun to drive. I can do some logs perhaps to see what's happening, but it's worth at least trying it out and helping COBB with the R&D!
Old Apr 24, 2010 | 01:06 PM
jackfrog's Avatar
thats exactly what happened to my car, i got the 1.07 from cobb, and same result like you stated. i really want to know the difference between 1.04 and 1.07, i feel 1.04 is smoother...i dont know how to log lol. btw what mods you have? do you have wb and see how the car runs? i dont have one so i wanna know if everything is fine...>_<
