Cobb AP issues - Cylinder 2 misfire
Old Apr 19, 2010 | 09:04 AM
strud's Avatar
Exclamation Cobb AP issues - Cylinder 2 misfire
Hello,
I have a 2010 Evo MR Touring. 6000kms. Have had the AP Stage 1 93octane installed since 1000kms. Car has been running like a dream on 94octane. The check engine light turned on yesturday while driving around. I used the AP and it showed as cyclinder 2 misfire. Reflashed the ECU and the light went off. About an hour later the light came back on. This time I reflashed to stock, and then reinstalled the Stage 1 93+. Check engine light came on again today. I completely uninstalled the AP and the light went off again. Any idea of whats going on?
Cheers
Old Apr 19, 2010 | 09:22 AM
Golden's Avatar
Pull the plugs and see what they look like. Post up a picture if you can.
Old Apr 19, 2010 | 03:43 PM
heavyD's Avatar
Sounds like a bad plug or coil.
Old Apr 20, 2010 | 02:21 PM
DarwinX's Avatar
Originally Posted by strud
Hello,
Cheers
Why to you continue to think it's the Cobb tune?
Pull the damn #2 plug and have a look see.
Old Apr 20, 2010 | 02:38 PM
ugakirk's Avatar
Yea. prolly a plug.
Old Apr 20, 2010 | 07:03 PM
RedEvoxGSR's Avatar
its prob nothing man!! jus check the plug and let us know what happens man!!
Old Apr 20, 2010 | 07:22 PM
Optiblue's Avatar
I'm going to guess it's the plug~ Congrats on the car purchase! Which gas are you using?
Old Apr 20, 2010 | 11:53 PM
TrackDays's Avatar
Has to be Husky 94 Only the best!
Old Apr 21, 2010 | 07:39 AM
Mad_SB's Avatar
The light goes off every time you flash the ecu because you are clearing the codes during the reset. As others have said, check the plugs / coilpack.
Old Apr 21, 2010 | 08:40 AM
strud's Avatar
Pulled all the plugs and cleaned them....check engine light still on. I replaced the #2 plug and everything is back to normal. Thanks guys!!!
I try to always run Chevron 94octane, but sometimes get stuck with Husky/Mohawk 94.
BTW, extremely happy with the car so far. My first mitsu, and it is a blast to daily drive.
Cheers,
Scott
Old Apr 21, 2010 | 11:55 AM
Optiblue's Avatar
Yeah those stock plugs are a hit and miss from the factory. Either they're perfect or have issues from the start! You should try out stage 2, it'll make u even happier. I actually find that I get less knock with husky!
onlynamenotused
15
Oct 13, 2018 11:48 AM
FoxFMX
Jul 9, 2015 11:05 AM
3000GT-GTO
Cobb AccessPORT
34
Aug 17, 2013 02:52 PM
bw1
Sep 27, 2012 07:12 PM
1fastvet
Feb 10, 2012 09:54 AM
