Need Some Help
Old Apr 24, 2010 | 04:25 AM
RaysEvoX's Avatar
Need Some Help
My turbo oil feed line busted. Got a new oil feed line from the dealership and put it in. I took off the the intake, upper intercooler pipe, the manifold, the downpipe and the turbo just to make sure nothing else was busted. Everything else was good. I got everything bolted back up and no problems except im throwing error codes. I get them read and here is what they are:
P0113(IAT Sensor High Input)
P0014("B" Camshaft Position - Timing Over-Advanced or System Performance Bank 1)
P0172(System Too Rich-Cylinders 1-4)
I cleared them and they came back on. How can I get them fixed/stop popping up?
Old Apr 24, 2010 | 06:05 AM
evilempire18's Avatar
are you sure everything is plugged back up? also P0014 can be caused by too much oil in the motor... is it overfilled? did you break a wire in the MAF connector?
Old Apr 24, 2010 | 06:11 AM
RaysEvoX's Avatar
Im sure verything is plugged back up properly. Ill check the oil and ill check the all wires on the MAF connector and o2 sensors. Thanks
Old Apr 24, 2010 | 01:33 PM
RaysEvoX's Avatar
Check the oil, it was a little ovr full. Drained some out. Erased the codes and so far so good. Thanks for the advice evilempire18.
Old Apr 24, 2010 | 11:34 PM
Brokenevo's Avatar
hope that was it bro, how did you break an oil line?
TURBODAWG
10
Mar 17, 2018 04:04 AM
Biggy VIII
Aug 9, 2016 03:06 PM
ILoveAWD
Jan 4, 2015 05:52 AM
diablo1
Jul 14, 2011 08:46 PM
Timebombxxx99
Mar 12, 2009 08:44 PM
