Stock Turbo New Injectors?
Old May 4, 2010 | 11:43 AM
knightey's Avatar
Hey,
So I am finally getting ready for my ProTune and have a question...With the stock turbo do I or should I be upgrading my injectors? Will the stock injectors be able to handle fuel needed with a ProTune on the stock turbo?
Part 2: If I need to upgrade to lets say 800cc injectors, do I need to also upgrade my fuel pump?
Please advise!!
Old May 4, 2010 | 12:10 PM
Golden's Avatar
Stock injectors should be good. (assuming you are using pump gas)
Old May 4, 2010 | 12:13 PM
nonschlont's Avatar
Originally Posted by knightey
Hey,
Please advise!!
all depends on mods, and boost. I realize u have a X, and I a IX, but same concept. Im on the stock turbo running ~24psi, and w/ my mods, Im maxing them out by ~ 6000... Just an example.
I would NOT go any lower than 1000cc inj.! later on, u WILL want more powa...
my .02
Old May 4, 2010 | 12:21 PM
nyc 93-2jzgte's Avatar
Like Golden said, you will be fine on pump gas. E-85 and you will need upgraded injectors (and pump). If you plan on upgrading the turbo in the future, might be good to upgrade the injectors anyway,.
Old May 4, 2010 | 12:40 PM
knightey's Avatar
Well I am running a full T1R Turbo-back along with TurboTrix intake and IC pipe kit with a Cobb AP...Going for a ProTune in a couple weeks, and plan on staying stock turbo for a little while...So I don't want to go over kill right now but want the maximze my set up while keeping it reliable...Its a daily driver/spirit driver so I'm trying to walk the fine line =)
Old May 4, 2010 | 01:27 PM
c_reber's Avatar
OK, and what type of fuel are you going to be using??? 91oct or E85?
Like everyone else said, normal 91 pump gas, stock injectors are fine. E85 ethanol, need to upgrade injectors.
Old May 4, 2010 | 09:16 PM
tephra's Avatar
E85 will REQUIRE larger injectors...
91 or 93 you should be fine (just) with the stockers on stock turbo...
Old May 10, 2010 | 11:19 AM
knightey's Avatar
Well I will be using 91 or 94 Octane pump gas nothing crazy as it is my daily driver....Thanks for the input....Planning on a bigger turbo down the line, si if the stock injectors are fine then one less thing I need right away
DrGr33nThumb215
Feb 14, 2013 07:41 PM
valin
Cobb AccessPORT
Nov 14, 2011 08:03 AM
phishy
Sep 8, 2011 05:46 PM
Clipse3GT
Jun 18, 2009 01:50 PM
hytek369
10
Sep 10, 2008 04:22 PM
