Tune Very Inconsistent
Old Jun 6, 2010 | 07:36 PM
tephra's Avatar
your high trim should be 0
what did you use for the Cruise LT Control mafhz?
Old Jun 6, 2010 | 07:38 PM
bandit09's Avatar
I used 343.75 and 350.00 mafhz for the LT control code you posted. The high trim goes to all 0's on my map tracer around and 100-120 load and after.
Old Jun 6, 2010 | 07:44 PM
tephra's Avatar
what mods do you have?
and what is your requestid (mode 23 address) for your MAFHz field you are logging? it should be 0x8087DB for 526800**
Old Jun 6, 2010 | 07:50 PM
bandit09's Avatar
My Mods are:
FP Red, ported and polished
ported and polished stock exhaust manifold
DW 1000CC injectors
AMS Fuel Rail
Ultimate Racing Fuel Filter & W 255 Fuel Pump Kit
AMS Intake
AMS Intercooler and IC pipes
Perrin Turbo-back exhaust
AEM UEGO wideband
AEM tru-boost controller
Running around 22-24 PSI of boost.
My Request ID for Maf HZ in evoscan is:
238087DB.
My rom id is 52680018
Old Jun 6, 2010 | 07:51 PM
tephra's Avatar
ok and what formula is evoscan using?
I ask because your log indicates the High Trim is changed at about 100 MafHZ, which is too low.
But your ROM says 350/343
Old Jun 6, 2010 | 07:56 PM
bandit09's Avatar
I meant it changes at 100 LOAD CELL not 100 mafHZ, I apologize thats what I meant to say.
Old Jun 6, 2010 | 07:57 PM
tephra's Avatar
just going to lunch, the formula (eval) should be x*6.25
if you can get another log for me, ONLY logging:
tps, load (any 1), mafhz, all 3 high trims, stft, rpm, boost, timing
Just idle + crusing around for 10 mins.. dont need togo WOT, just normal driving, like takeoff normally and cruise...
I think your intake is screwing up things a bit its ok thou
Old Jun 6, 2010 | 08:01 PM
bandit09's Avatar
Yes, the formula is x*6.25
I will go out right now and do the log and then try to upload it here, if it's too big I'll throw it in a zip file and upload it to my buddy's webserver or if your browser somehow has an attachment to read excel csv datalog files I could just upload the file and not put it in a zip. Actually I will do both.
Thank you so much for trying to troubleshoot this with me.
Old Jun 6, 2010 | 08:30 PM
bandit09's Avatar
Okay sir, went out and logged the specified items for about 10 mins. just normal driving, occasional boost conditions.
The forum won't let me upload the logfile because it's a .csv but here it is, I uploaded it to my buddy's webserver. I put it in a zip and also just uploaded the file itself.
Here they are:
Zip: http://phatlogic.com/Evo/Bandit09%20...20-%20Log2.zip
Excel CSV: http://phatlogic.com/Evo/EvoScanData...6_23.05.35.csv
Thanks so much Tephra!
Old Jun 6, 2010 | 08:36 PM
tephra's Avatar
whats your requestid for the 4 trims (STFT, Low,Mid,High)?
Old Jun 6, 2010 | 08:40 PM
bandit09's Avatar
here are the request id's i got from my evoscan for the following trims:
stft - 23808898
ltft idle - 23804573
ltft cruise - 23804575
ltft high - 238088A9
Old Jun 6, 2010 | 08:41 PM
tephra's Avatar
ahh
your high should be 23804577..
no wonder its weird
Old Jun 6, 2010 | 08:46 PM
bandit09's Avatar
Hmmm okay I updated it in Evoscan. Should I go out and do the same thing you just said? Drive around normally for like 10 mins? Then come back and post the log?
Old Jun 6, 2010 | 08:50 PM
tephra's Avatar
yep - just a 5 min drive would do...
take off normally, cruise, maybe get upto 10psi for a little bit...
Old Jun 6, 2010 | 08:51 PM
bandit09's Avatar
cool I will go do that right now and post back.
