Extremely Lean ARF's Under Boost
Old Jul 7, 2010 | 02:49 PM
gripbox's Avatar
try your relay. If it's still not working, revert back to stock and have a tuner check out your maps...given that your tune was done properly
Old Jul 7, 2010 | 06:06 PM
gotrnet's Avatar
thank you to everyone for your input and help, seems the problem may have been the RELAY. i replaced the stock one with the Blue one and presto, uber rich stock tune and a great running custom tune.
on a side note, i am pretty amazed that this issue was caused by the relay. i figured if the relay was the issue that it would not have cranked at all. i never thought that it would only screw up under boost, or actually due to voltage more than likely. anyway thanks again, and i hope someone in the future finds this thread helpful.
Old Jul 7, 2010 | 07:32 PM
Golden's Avatar
The relay controls the low voltage / high voltage that is sent to he fuel pump. It's normally in low voltage. If it doesn't kick into high voltage under high load, your car goes boom.
Old Jul 7, 2010 | 07:35 PM
tephra's Avatar
yeah, pretty **** design from Mitsu..
Old Aug 2, 2010 | 12:34 PM
Wht9er's Avatar
Im getting my evo x soon. Can someone please direct me where on the car the relay is along with a place to buy the new correct relay (and what exactly the correct relay is)
Old Aug 2, 2010 | 12:48 PM
gotrnet's Avatar
here is a picture showing the relay location.
from post #53 in this thread.
Originally Posted by Noize
http://www.mitsubishiparts.net/catalog/?section=617
Put in a line message to switch to USPS, and they will only charge $6 for freight.
I spoke to Russell directly. They will get the correct BLUE relay out.
https://www.evolutionm.net/forums/ev...-page-4-a.html
Old Aug 2, 2010 | 01:03 PM
Wht9er's Avatar
This is perfect. Thank you very much!
Old Oct 13, 2014 | 06:38 PM
max4rw's Avatar
im having problems at wot between 6k to 7k almost always in 3rd and 4th gear, the car will stutter... could this be the cause of a bad fuel pump relay? the car is brand new 2014 gsr completly stock with ruffly 1300 miles on it any help would be much appreciated
Old Oct 31, 2014 | 05:57 PM
Xuracing's Avatar
This is probably a stupid question.
But I have seen people neglect this portion quite frequently.
Was the wideband properly calibrated to open air?
shane_evo7
Mar 7, 2019 05:49 PM
Alchem1st
Jul 28, 2017 01:15 PM
awdordie
17
Feb 26, 2017 09:16 PM
Benson830
Nov 8, 2016 09:32 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
