Logs from EF4 Built X - !!!!
Old Nov 2, 2014 | 08:54 AM
Semih321's Avatar
Gentleman attached you will find my log sheet done with evoscan w/ RAX patch of which I cleaned up. Please take a look and tell me your thoughts! Mods are as follows;
2011 GSR w/ interior leather, navi, SS package (all leather heated seats)
EF4 new w/ anti surge and porting options with larger WG spring
ETS tubular 1.90 runner exhaust mani
MAP DP w/ open dump
ETS Test pipe
UT racing exhaust 3' w/ 4' tips
ETS IC, UICP
Custom LUICP
Injen intake w/ stock Maf
Built 2.0 stock sleeves with Manley I Beams, Weisco Pistons, ACL rod bearings, wrist pins, main studs, head studs, new timing chain and full gasket kit.
Stock Head.
Grimspeed 3 port BC
Synapse DV BOV kit
ID1000CC PnP injectors
Walb 400 LPH hardwired
Comp stage 3 clutch kit w/ stainless steel flywheel option
Works short shifter kit w/ all bushings.
AEM UEGO digital AFR gauge
DEFI boost gauge
OEM Enkies w/ fresh tires and fresh alignment
File Type: pdf
Old Nov 2, 2014 | 08:59 AM
Semih321's Avatar
Anyone know how I can upload an excel file?
turboimpala
Apr 10, 2013 12:36 PM
PRS
Evo X Dyno Results
87
Sep 7, 2012 05:16 AM
Mikey@Spec-Ops
Feb 10, 2012 02:48 PM
Beeble
Jan 3, 2012 10:23 PM
cul8tr
Nov 21, 2011 12:42 AM
