who wants to test the +30psi = ASC OFF fix?
Old Jul 15, 2010 | 07:10 AM
  #31
murlo26's Avatar
Originally Posted by tephra
that I havn't looked at yet.
i have a feeling that the SD part is only for when the MAF sensor fails.... but once this 30psi thing is done, and the throttle lookups done, and some more tephraxmods are done ill look into the SD/MAF thing hehee
I like where this is going
Old Jul 15, 2010 | 09:40 AM
  #32
Clipse3GT's Avatar
Tested the newest version of the fix... so far so good.
Old Jul 15, 2010 | 09:44 AM
  #33
murlo26's Avatar
So is this fix simply adding to our current ROM by using a definition and getting new tables?
Or do we need a whole new Rom?
Old Jul 15, 2010 | 09:49 AM
  #34
Clipse3GT's Avatar
Just added definition to the ROM.
But, I am not sure what the final version will entail. Still in testing. Working for MR and GSR.
Old Jul 15, 2010 | 10:04 AM
  #35
fostytou's Avatar
EvoM Community Team
Sweeeet!
Old Jul 15, 2010 | 11:52 AM
  #36
GST Motorsports's Avatar
Time to stock up on some shortblocks.
- Bryan
Old Jul 15, 2010 | 12:02 PM
  #37
murlo26's Avatar
Check, got it
Old Jul 15, 2010 | 12:03 PM
  #38
tsitalon1's Avatar
Show off!
Old Jul 15, 2010 | 12:16 PM
  #39
murlo26's Avatar
Originally Posted by tsitalon1
Show off!
Old Jul 15, 2010 | 04:22 PM
  #40
tephra's Avatar
what bore murlo?
Old Jul 15, 2010 | 04:59 PM
  #41
JohnBradley's Avatar
its voltage based.
so if you put a 4bar in then this wouldn't happen at 30psi, but probably 40psi..
but doing that introduces another set of problems... like ALL the MAP scalings would be off, and its not easy to just fix them up....
Alters fueling by 20-22% (lean) and then its okay
Already done tested that a long time ago....forgot to post...whoops.
Old Jul 15, 2010 | 05:30 PM
  #42
tephra's Avatar
ORLY?
did you update the scaling for the new sensor? or just wack it in?
Old Jul 15, 2010 | 05:43 PM
  #43
murlo26's Avatar
what bore murlo?
STD, 86mm, didn't have enough dough to go to an overbore kit, maybe in the future. Plans are to rev it out instead, 9.5k for track days I am guessing.
AMS Spec JE pistons ftw
Old Jul 15, 2010 | 05:44 PM
  #44
tephra's Avatar
proper thread on the fix:
https://www.evolutionm.net/forums/ev...off-fixed.html
Murlo - would it have cost an extra? I presume you went with Darton sleeves? or is that stock?
Old Jul 15, 2010 | 05:48 PM
  #45
murlo26's Avatar
Stock sleeves, brand new OEM shortblock.
It was at least 1800 from Darton for the sleeves and machine work plus more downtime. With my fully built head, all upgraded internals and new OEM block I am already close to 10k, i just can't afford that much at once. If/when I get bored with the car I am prolly going to do the ERL 2.5L stroker/overbore kit. ETS took the stock sleeves up to 800whp already and buschur said he hasn't seen any reason to upgrade them yet either on stock bore 86mm.
