Reduction of load values, what could cause?
Old Jul 21, 2010 | 02:08 PM
LVSBB6's Avatar
I was dyno-tuning on the same dynapack which I used previously and noticed a drop of load values in my datalog.
Car is running 28psi tapering to 25psi, I was hitting 280-300 load values before but now my load values doesn't go pass 260 while running at the same boost.
The dyno settings are confirmed to be identical, and because of the loss in load, I'm making less power as well.
We checked and ensure there is no boost leak or fuel issue, spark plugs are fresh. There is no mis-fire or exhaust leak either. TPS is at 95% confirming TCU did not kick-in.
What else can you guys think of?
Old Jul 21, 2010 | 02:47 PM
SilverEvoX's Avatar
MIVEC settings can change you'rere load, were they modified in your most revised tune? Did you check cylinder compression?
Old Jul 21, 2010 | 03:10 PM
LVSBB6's Avatar
MIVEC was not touched, compression is there.
Old Jul 21, 2010 | 03:50 PM
LaXGSR's Avatar
Temperature maybe? On a stock car (tuned), my peak load is about 20-30 points less in the summer than the winter.
Old Jul 21, 2010 | 04:59 PM
LVSBB6's Avatar
That's what I'm suspecting.
Normally at 28psi during cool days, I would be hitting 280 to 290 load cells.
But today at 28psi, I was only hitting 250 load cells.
Anyone else confirm the same experience?
Old Jul 21, 2010 | 05:33 PM
E6-X's Avatar
not surprised, the weather conditions heat, RH,Baro does plays a big role.
same type of fuel ?
what are the power/tq diffs ?
just outta curiosity, why are you on dyno if nothing has changed or added/taken out ?
Old Jul 21, 2010 | 06:34 PM
LVSBB6's Avatar
I put in a new BOV and needs a re-tune.
Same 94 oct fuel, same boost curve, same timing, fuel spot on at 11.0-11.1.
I was losing around 15% of power and torque, roughly the same percentage loss in the load I was hitting.
Old Jul 22, 2010 | 03:37 AM
E6-X's Avatar
weather is most likely the culprit be nice to mother nature LoL stop polluting hahaha u need a HUGE CAT LVSBB6 j/k .
Old Jul 22, 2010 | 05:30 AM
SilverEvoX's Avatar
Why do you have it tuned so rich still post tune? 11 flat is very conservative IMO especially with 94 octane. Have you disabled your LTFT? Those could also be playing a factor if the car goes leaner/richer at times varying on your LTFT which would in turn probably reduce or increase your load.
Old Jul 22, 2010 | 05:32 AM
tsitalon1's Avatar
I agree, change in temps/humidity.
Slightly off topic but shouldn't you be hitting more than 280 load on cooler days?
I ask because my stock turbo hits 280 load at 28psi if my temps are around 50ºF, I would've thought a Green could hit 320 at least.
Old Jul 22, 2010 | 07:56 AM
fostytou's Avatar
EvoM Community Team
Weather. Also, if your old BOV was a boost leak then that would make the load appear higher.
Old Jul 22, 2010 | 09:19 AM
LVSBB6's Avatar
This morning`s temperature reduced by about 8 degrees so I datalogged a few back to back pulls, I`m happy to report that my load values has increased back to 280-290 range. Although I still find it`s a little under 1 to 10 ratio after a few hot pulls at 16 degrees celcius.
Looks like it is infact the temperature /humidity that were affecting my dyno pulls yesterday indeed.
Old Jul 22, 2010 | 12:37 PM
kozmic27's Avatar
It is possible that your wgdc is limiting your boost rather than load limiting your boost, causing you to have lower load values when the air is less dense. If you are logging boost error correction, and you see that it is maxed at 10, then your wgdc is your limit, rather than load. If you have a value less than 10, you are hitting target loads. (unless you changed your maximum upward wgdc correction)
Old Jul 22, 2010 | 04:00 PM
LVSBB6's Avatar
I don`t recall seeing boost error correction during the runs. But in my case where the actual boost is already in-line with the the tune, I suspect that error correction won`t exist.
It was my load that was low, not boost.
Old Jul 22, 2010 | 09:40 PM
LVSBB6's Avatar
Interesting point. My previous BOV did leak in high boost, I just replaced it with HKS SSQV-R which doesn't leak. And if your theory is right, maybe that also explains why my load is lower now in comparison.
