Engine heistation... not BOV... what else could it be?
Old Aug 16, 2010 | 10:41 PM
Methodical4u's Avatar
I contacted my tuner and he said that it was likely the BOV since I was at a lower RPM level and sometimes the BOV doesn't know when to open and close. Golden suggested to try tightening it, which I did put a turn on it, but it still had the same thing... I don't know how much adjusting is enough.
Tephra suggested to loosen the BOV all the way... no go.
Golden suggested to put the OE BOV back on ... I was so hoping this was the problem... no go.
Any ideas on this?
Old Aug 16, 2010 | 10:46 PM
I am trying to get the log posted up... but you can clearly see the knock right where the hesitation is happening.
Old Aug 16, 2010 | 10:50 PM
Old Aug 16, 2010 | 10:51 PM
this was from yesterday... most of you who are good with tuning will know what the numbers are, but in case not cell M is the knock and that is where the issue is happening.
Old Aug 16, 2010 | 11:08 PM
I'll take this log off since it's making the page so wide.
Old Aug 16, 2010 | 11:09 PM
from tonight.
Old Aug 17, 2010 | 12:58 AM
tephra's Avatar
oh i thought it was happening not at WOT..
well 2-3 KS isn't anything to worry about...
are you sure thats the right bit of the log?
Old Aug 17, 2010 | 01:09 AM
yeah, I logged the 5th gear runs where it does it... around 50 or so, then 65 then 75-80... it's just jumping around... it does it in other gears too, but this is the most common time... would just reflashing my tune over maybe help it to take away what the car might be doing now? I'm close to 15k, should I consider some early maintenence? New spark plugs? I'm about to change the rear gear fluid anyway. If so, which plugs are the best ones I should get?
Old Aug 17, 2010 | 01:25 PM
bump for any other ideas to try? I'm going to reflash the same tune and see if it makes a difference, but if not... plugs? air filter check? boost lines? (which all look ok when I did a quick go over, anything else? I know like Tephra said it doesn't really look bad... but it feels like the car is just sick and I am very particular about my car and that hesitation and bumpy feeling sucks major ***.
Old Aug 17, 2010 | 01:33 PM
GST Motorsports's Avatar
You have some crazy WGDCC going on there.....
I'd also look at your mivec in those regions as it might be a tad too aggressive and surging the car... Lower that and it should smooth it out
- Bryan
Old Aug 17, 2010 | 01:41 PM
- Bryan
I can log it and post it... I have NO idea how to do any of this stuff aside from that lol
Old Aug 17, 2010 | 02:45 PM
LogIDLogEntryDateLogEntryTimeLogEntrySeconds TPS2ByteRPMLoadFuelLoadMIVEC TimingAdvKnockSumOctaneAFRMAPBoost
18/17/201025:22.10.63486 1.0117647062480.468751514.6875 00  -10.6789675
28/17/201025:22.30.86715 1.0117647062449.2187514.687514.6875 00  -10.6789675
38/17/201025:22.51.07543 2.0235294122445.312515.937515.9375 400  -10.6789675
48/17/201025:22.71.26017 2.0235294122417.9687516.87516.875 400  -10.4854975
58/17/201025:22.91.42783 2.5294117652433.5937517.812517.8125 400  -10.2920275
68/17/201025:23.11.60736 3.0352941182414.062519.062519.0625 400  -10.05019
78/17/201025:23.21.77285 4.5529411762406.2521.2521.5625 400  -9.4214125
88/17/201025:23.41.94161 10.623529412410.1562530.937532.8125 400  -6.2291575
98/17/201025:23.62.11197 15.682352942414.06255555 320  -3.182005
108/17/201025:23.82.30657 17.22410.1562563.12563.4375 280  -2.214655
118/17/201025:23.92.47691 18.211764712421.87569.062569.375 260  -1.73098
128/17/201025:24.12.66717 20.235294122421.87572.573.4375 260  -0.7152625
138/17/201025:24.32.83604 24.282352942441.4062583.7584.0625 220  0.4455575
148/17/201025:24.53.0056 29.847058822445.312593.12594.0625 210  1.7031125
158/17/201025:24.63.17485 29.341176472453.12594.687595 210  2.2835225
168/17/201025:24.83.34493 28.835294122472.65625104.0625104.375 200  3.1541375
178/17/201025:25.03.51601 29.847058822484.375111.25111.875 170  3.976385
188/17/201025:25.13.68467 31.364705882500117.1875116.5625 170  4.943735
198/17/201025:25.33.85369 31.364705882515.625123.4375123.125 160  5.81435
208/17/201025:25.54.02384 30.858823532531.25125125 150  6.8300675
218/17/201025:25.74.21066 31.870588242558.59375135135.625 130  7.94252
228/17/201025:25.84.37886 35.411764712566.40625144.6875145 120  9.2484425
238/17/201025:26.04.54783 35.411764712597.65625152.1875152.5 110  10.360895
248/17/201025:26.24.71765 34.905882352625151.5625152.1875 110  11.6668175
258/17/201025:26.34.88829 34.42636.71875158.125158.75 100  12.876005
268/17/201025:26.55.05687 33.894117652679.6875165.3125165.625 100  14.0851925
278/17/201025:26.75.22673 33.894117652695.3125172.8125173.125 100  15.197645
288/17/201025:26.85.39688 33.894117652742.1875180180.3125 100  16.7937725
298/17/201025:27.05.5668 31.364705882761.71875185.3125185.625 100  17.325815
308/17/201025:27.25.73588 29.341176472800.78125189.0625189.6875 100  17.906225
318/17/201025:27.45.90566 22.258823532824.21875185.9375183.125 100  15.3427475
328/17/201025:27.56.07592 19.223529412851.5625152.8125161.25 110  9.3451775
338/17/201025:27.76.24475 19.729411762832.03125147.1875142.5 140  8.7164
348/17/201025:27.96.41473 19.729411762695.3125128.75134.0625 170  8.7164
358/17/201025:28.06.58477 22.764705883003.90625149.0625152.8125 120  11.42498
368/17/201025:28.26.75474 24.282352942929.6875157.1875157.5 100  12.39233
378/17/201025:28.46.92392 24.282352942949.21875162.8125163.125 100  13.262945
388/17/201025:28.57.09367 24.282352942972.65625169.0625169.375 100  14.0851925
398/17/201025:28.77.26379 23.776470593015.625172.8125172.8125 100  14.5688675
408/17/201025:28.97.43397 23.270588243027.34375172.1875173.75 100  15.0525425
418/17/201025:29.07.60283 23.270588243050.78125180180.3125 110  15.87479
428/17/201025:29.27.77276 23.270588243117.1875181.875181.875 110  16.2133625
438/17/201025:29.47.94293 23.270588243105.46875178.75176.25 110  16.6003025
448/17/201025:29.68.11185 23.270588243156.25167.1875167.1875 110  12.8276375
458/17/201025:29.78.28173 23.270588243132.8125165.625151.875 40  12.9243725
468/17/201025:29.98.45187 23.270588243039.0625157.8125152.5 97  11.7635525
478/17/201025:30.18.62167 23.270588243246.09375170.3125171.25 86  13.9884575
488/17/201025:30.28.79086 23.270588243203.125175175.3125 86  14.9558075
498/17/201025:30.48.96077 23.270588243261.71875179.375180 76  15.8264225
508/17/201025:30.69.13084 23.270588243285.15625185.3125186.5625 76  16.938875
518/17/201025:30.89.30026 22.764705883308.59375190.3125190.9375 76  17.61602
528/17/201025:30.99.46989 23.270588243328.125192.8125180.3125 75  14.9558075
538/17/201025:31.19.63997 23.270588243363.28125136.875148.125 115  13.0211075
548/17/201025:31.39.81024 22.258823533324.21875156.875158.75 -55  14.810705
558/17/201025:31.49.97999 22.764705883375184.0625177.5 75  14.9558075
568/17/201025:31.610.14981 22.764705883460.9375165.9375177.5 75  16.0198925
578/17/201025:31.810.31884 22.764705883429.6875174.375185.9375 74  16.358465
588/17/201025:31.910.48898 22.764705883519.53125153.4375141.5625 144  12.8276375
598/17/201025:32.110.65781 22.258823533453.125170.9375181.5625 74  14.9558075
608/17/201025:32.310.82803 21.752941183550.78125144.375140.3125 154  14.2786625
618/17/201025:32.510.99778 21.752941183539.0625154.6875147.5 123  11.03804
628/17/201025:32.611.16792 21.247058823460.9375156.25155 93  12.682535
638/17/201025:32.811.3368 20.235294123593.75150.3125153.125 93  10.360895
648/17/201025:33.011.50703 19.729411763523.4375141.5625153.4375 93  11.3766125
658/17/201025:33.111.67684 19.729411763714.84375130.625127.5 193  8.32946
668/17/201025:33.311.84667 20.235294123496.09375139.6875136.875 172  9.10334
678/17/201025:33.512.01597 19.223529413660.15625129.0625125.625 211  7.7974175
688/17/201025:33.612.18621 19.223529413675.78125120.3125116.25 230  6.298025
698/17/201025:33.812.35601 19.729411763710.9375117.1875124.375 210  7.0235375
708/17/201025:34.012.52486 19.223529413660.15625123.125123.125 210  7.071905
718/17/201025:34.112.69498 19.223529413710.9375123.75124.0625 210  7.36211
728/17/201025:34.312.8649 19.223529413714.84375125.3125125 210  7.652315
738/17/201025:34.513.03504 19.223529413734.375126.25126.25 220  7.8941525
748/17/201025:34.713.20383 19.223529413750127.5127.5 220  8.13599
758/17/201025:34.813.37501 19.223529413769.53125129.6875129.6875 210  8.32946
768/17/201025:35.013.54419 19.223529413789.0625132.1875132.1875 210  8.619665
778/17/201025:35.213.713 19.223529413804.6875122.8125126.25 220  8.426195
788/17/201025:35.313.8829 19.223529413816.40625130.9375135 200  8.4745625
798/17/201025:35.514.05299 18.717647063898.4375113.125119.6875 230  5.23394
808/17/201025:35.714.24462 18.717647063777.34375105.3125117.5 240  4.0247525
818/17/201025:35.914.44193 18.211764713992.1875102.1875101.25 260  4.363325
828/17/201025:36.114.61186 18.211764713832.03125101.25101.25 260  3.782915
838/17/201025:36.214.78167 17.705882353906.2599.37599.375 260  3.68618
848/17/201025:36.414.95088 17.705882353882.812597.187596.5625 270  3.29924
858/17/201025:36.615.12077 17.23910.1562596.562596.25 270  3.0574025
868/17/201025:36.715.29083 17.705882353914.062596.2596.25 270  3.0574025
878/17/201025:36.915.46125 17.705882353925.7812596.2596.5625 270  3.009035
888/17/201025:37.115.62987 17.23929.687595.62595.9375 270  2.8639325
898/17/201025:37.315.801 17.23937.595.312594.375 270  2.2835225
908/17/201025:37.415.96984 15.682352943964.8437580.937581.25 290  0.59066
918/17/201025:37.616.13877 15.682352943957.0312572.572.8125 310  -1.053835
928/17/201025:37.816.30892 15.682352943839.8437570.937576.25 310  -1.053835
938/17/201025:37.916.47892 15.176470593914.062564.062569.0625 320  -1.440775
948/17/201025:38.116.64894 15.682352943968.7570.62570 320  -1.2956725
958/17/201025:38.316.81893 15.682352943941.4062569.062568.75 320  -1.53751
968/17/201025:38.416.98798 15.176470593953.12565.62565.625 320  -1.92445
978/17/201025:38.617.15782 15.176470593957.0312564.687565.625 320  -2.0695525
988/17/201025:38.817.32712 15.176470593964.8437565.312565.625 320  -1.9728175
998/17/201025:39.017.49693 15.176470593964.8437565.312565.3125 320  -1.92445
1008/17/201025:39.117.66697 15.682352943964.8437565.312565.625 320  -2.021185
1018/17/201025:39.317.83699 15.682352943960.937567.568.125 320  -1.73098
1028/17/201025:39.518.00583 16.188235293972.6562569.062569.375 330  -1.5858775
1038/17/201025:39.618.17603 16.188235293976.562570.312570.3125 320  -1.2956725
1048/17/201025:39.818.34589 17.23976.56257575.3125 320  -0.8119975
1058/17/201025:40.018.516 17.705882353984.37578.437579.0625 300  -0.3283225
1068/17/201025:40.118.68478 17.705882353988.2812582.187582.1875 300  -0.1348525
1078/17/201025:40.318.85496 18.211764713992.187586.562586.5625 290  0.6390275
1088/17/201025:40.519.02484 18.717647064007.812590.937591.25 280  1.1227025
1098/17/201025:40.619.19385 18.717647064007.812593.7594.375 280  1.6063775
1108/17/201025:40.819.36385 19.223529414019.5312599.687599.0625 270  2.4769925
1118/17/201025:41.019.53387 19.223529414031.25103.125103.125 270  3.10577
1128/17/201025:41.219.70384 19.223529414035.15625104.6875104.6875 270  3.5410775
1138/17/201025:41.319.87291 19.223529414054.6875109.0625109.6875 260  4.07312
1148/17/201025:41.520.04285 19.729411764066.40625113.4375113.75 250  4.556795
1158/17/201025:41.720.21417 19.223529414074.21875115.3125115.625 250  4.943735
1168/17/201025:41.820.38286 19.223529414089.84375118.4375118.4375 260  5.3790425
1178/17/201025:42.020.552 19.223529414113.28125120.3125120.3125 250  5.81435
1188/17/201025:42.220.72186 19.223529414121.09375122.1875122.5 250  6.104555
1198/17/201025:42.320.89201 18.211764714132.8125122.5122.5 250  5.7659825
1208/17/201025:42.521.06094 16.694117654148.4375102.5103.75 270  2.5737275
1218/17/201025:42.721.23078 11.129411764160.1562566.562564.6875 330  -3.4238425
1228/17/201025:42.821.40081 10.623529414164.06255047.8125 380  -5.40691
1238/17/201025:43.021.59499 11.129411764105.4687548.12547.8125 380  -5.60038
1248/17/201025:43.221.76488 11.635294124156.2542.187545.625 390  -6.2291575
1258/17/201025:43.421.93599 11.635294124140.62541.562540 390  -6.470995
1268/17/201025:43.522.10491 11.635294124128.906254039.375 390  -6.857935
1278/17/201025:43.722.2749 11.635294124117.187535.937534.375 400  -7.244875
1288/17/201025:43.922.4439 6.5764705884105.4687527.187526.25 400  -9.6148825
1298/17/201025:44.122.61386 5.0588235294097.6562519.687519.375 400  -10.340395
1308/17/201025:44.222.78425 5.0588235294085.937515.937515.625 400  -10.533865
1318/17/201025:44.422.95299 5.0588235294082.0312515.312515.3125 400  -10.6306
1328/17/201025:44.623.12285 5.0588235294062.51515 400  -10.6789675
1338/17/201025:44.823.29296 4.5529411764046.87514.062514.0625 400  -10.8724375
1348/17/201025:44.923.4618 4.5529411764031.2513.7513.75 400  -10.8724375
1358/17/201025:45.123.63442 4.5529411764015.62513.7513.75 400  -10.920805
1368/17/201025:45.323.80192 4.0470588244007.812513.437513.4375 400  -11.0659075
1378/17/201025:45.423.97206 4.0470588243992.187513.437513.75 400  -11.01754
1388/17/201025:45.624.14103 4.0470588243988.2812513.437513.4375 400  -11.0659075
Old Aug 17, 2010 | 02:46 PM
reflashed the ROM again... not a single change. What I don't understand is after it was tuned it was fine.. it just started doing this... could it be the motor is just going up?
Old Aug 17, 2010 | 02:59 PM
derekste's Avatar
lets see a log with WGDC... your boost is all over the place
Old Aug 17, 2010 | 03:25 PM
damnit, I thought I logged that.
