Fuel level affects A/F ratio - look here
Old Nov 5, 2010 | 04:16 AM
tsitalon1's Avatar
Update:
It appears moving the pump up about 3/4" resolved the issue.
I have had the same A/F readings from full tank to 1 bar left on the gauge.
The only logic I can think of is that if the pump is sitting on it's filter sock, it could prevent fuel from coming in on the bottom side of the sock...
Old Nov 5, 2010 | 10:24 AM
Clipse3GT's Avatar
I know I'm awesome...
I'm sure there either wasn't enough fuel being sucked by the venturi effect causing a small lean out issue.
Old Nov 5, 2010 | 10:50 AM
tsitalon1's Avatar
You are a God amonst men.
No seriously, thanks for the help, I really appreciate all that you have done for me and the rest of this community.
Old Nov 5, 2010 | 12:00 PM
Hiboost's Avatar
Interesting, could have been the fuel filter sock design as well, the one you used seems smaller than most and if it was half clogged plus blocked on one side it could have been a restriction.
Old Nov 5, 2010 | 12:38 PM
tsitalon1's Avatar
Idk, I did reuse that filter though.....never took it off the pump.
ElectricBlueIX
Oct 30, 2013 03:44 AM
goofygrin
86
Aug 6, 2013 08:09 AM
nightshad0w
Feb 13, 2011 11:58 PM
Dem_z
Lancer Aftermarket Forced Induction Tech
26
Jan 17, 2007 02:01 PM
