How to connect to EcuFlash
Old Nov 3, 2010 | 02:17 PM
5LEEPERISAH23I's Avatar
Anyone know how to connect to EcuFlash with the Evo 10..
I can connect to Evo 8's n Evo 9' but i cant find out were to plug the 12 pin cable? do i need a different plug or is it located in a different spot
Old Nov 3, 2010 | 02:26 PM
mightybee's Avatar
I think its a different plug for the X's
http://www.tactrix.com/index.php?opt...d=17&Itemid=53
Old Nov 3, 2010 | 03:01 PM
fostytou's Avatar
EvoM Community Team
Niiiiice.
You didn't, by chance, just try plugging into the OBD port and attempt to read did you? The monstrosity of that just working would have been better left for Oct 31st....
Old Nov 3, 2010 | 03:25 PM
Originally Posted by fostytou
Niiiiice.
pluging into just OBD wont work
Old Nov 3, 2010 | 03:45 PM
tephra's Avatar
for EvoX you need an OP20 cable..
also there is no need for the white connector, just the OBD connector...
Old Nov 3, 2010 | 03:52 PM
so can i just use OBDII for the Evo X and not the white connector and EcuFlash will work?
bec in the 8's n 9's u need both the OBDII and the white connector
Old Nov 3, 2010 | 04:37 PM
tephra's Avatar
what I said...
Old Nov 3, 2010 | 06:07 PM
what I said...
ok sweet so on an Evo X i just use the OBDII port to use Evoscan and EcuFlash? Correct
Old Nov 3, 2010 | 06:18 PM
tephra's Avatar
correct - with the Tactrix OpenPort 2.0 cable...
Old Nov 3, 2010 | 06:49 PM
Thanks alot for ur help
mmixan
Sep 17, 2011 04:29 PM
s.lamoureux
Dec 5, 2010 02:38 PM
w evo
Jun 8, 2009 07:54 PM
Tuner@Swift
Feb 18, 2007 10:21 AM
