help with disable
Old Feb 11, 2012 | 03:53 PM
  #31
derekalan546's Avatar
anyone have a clue on how to disable the p0365 code yet? everyone with a base lancer that turbod there car gets this code but i dnt understand why i still have it when i have the evo x engine ...Its gatta be the Ecu because thats the only thing i still have stock with the evo map on it
Old Mar 28, 2012 | 12:28 PM
  #32
LiX's Avatar
LiX
Can we just disable readings from that sensor not to be reported as errors? It should clear the CEL.
Can anyone knowledge guy look into this? I will donate if solution is found for this error.
Old Jun 25, 2012 | 01:20 PM
  #33
LiX's Avatar
LiX
Anyone? There should be a software fix for this.
Old Aug 4, 2012 | 03:17 AM
  #34
ZZZ's Avatar
ZZZ
Am I right in understanding that exhaust cam actuator definitely fix the p0365? There could be a SW solution but its all assembly stuff and I guess only gurus can sort out this.
Old Aug 5, 2012 | 07:28 AM
  #35
Carvs's Avatar
Just some more insight for everyone.
I am running a 4B11T motor in my car as well with the stock Lancer ECU, I am still getting p0365. My tuner and I discussed the issue, as I have a couple codes on my car as we speak. One issue might be due to how the ECU's are pinned. If I'm not mistaken, both ECUs are pinned differently, which obviously would cause communication issues with components. I'm going to try repinning my ecu one I find the electrical diagram for both harnesses.
Old Aug 5, 2012 | 08:26 AM
  #36
LiX's Avatar
LiX
Pinout is the same for both ECM modules. Crankshaft and Camshafts sensors are on the same pins in both ECMs. Probably the problem is the phases, cause this is different when comparing Lancer & Evo service manuals.
Old Aug 5, 2012 | 02:01 PM
  #37
ZZZ's Avatar
ZZZ
Are there info on phases in the SMs? . Please give me the page number.
Right, pinouts are the same for all 4B engines, they just have more or less functional pins - for BCS or 2nd IAT, etc.
Old Aug 10, 2012 | 11:13 AM
  #38
tons0torque's Avatar
Can somebody tell me the differences in the crank reluctor rings? I have a evo x with a built motor and I'm getting a p0365 code and no start. Because I bought a new motor, I am thinking that this motor might possibly have a 4b11na ring in it.
Apparently, the differences is orientation on the crankshaft. So, there must be code somewhere in the NA lancer that is still looking for the old cam phasing?
So if you run a x ecu and 4b11t you also get the p0365?
My problem is, that with the wrong ring (I think this is the issue), my car won't start at all. . . .
Old Aug 10, 2012 | 11:23 AM
  #39
LiX's Avatar
LiX
Nobody has tried running Evo X ECM on NA Lancer, maybe it will cure the issue.
We don't have such issue with starting. Are you sure you don't have any additional DTCs, cause P0365 only disables MIVEC. If the ring is different you should have more DTCs...
Old Aug 11, 2012 | 02:28 PM
  #40
ZZZ's Avatar
ZZZ
+1
I would also donate if Tephra changed ICS indicator (while changing alt maps) to something different, NA combo meters don't have it .
Old Dec 16, 2012 | 03:54 AM
  #41
LiX's Avatar
LiX
P0365 has gone by replacing the ECM with Evo X one.
P0098 has gone by wiring IAT2 sensor to the ECM.
Old Aug 14, 2014 | 05:10 PM
  #42
dentist's Avatar
Originally Posted by tephra
Ill fix P0098 first
Can you please log MUT46 to make sure you are getting 0 or 5volts.
Then do this:
52680022:
<table name="P0098 Disable 0xEA -> 0x100" category="Misc" address="546a0" type="1D" scaling="Hex16"/>
Hi tephra!!!
i need some help with P0098
in 53040010:
<table name="P0098 Disable 0xEA -> 0x100" category="Misc" address="546ae" type="1D" scaling="Hex16"/>
am i right?
Old Jan 23, 2021 | 06:06 AM
  #43
supattanapong's Avatar
Ill fix P0098 first
Then do this:
52680022:
hi bro
fix p0098 5304007 thx
SalD
Lancer Engine Management / Tuning Forums
Jan 23, 2019 08:55 AM
erixon84
Lancer Engine Tech
Mar 8, 2015 06:09 PM
lancer2008
Jul 25, 2013 06:08 PM
And
May 14, 2010 11:13 AM
dadsgts
Apr 15, 2010 05:04 AM
