Boost only @ 17-19psi max?
Old Mar 15, 2011 | 06:46 PM
HPEVOX's Avatar
I think it may be leaking now!! It was kind of erratic today 3-5th gear it would spike to 26 but drop to 17 then up to 21 back to 16. I was like What The?? I've gotta look super hard I guess. "Thought" it was all tight.
Old Mar 16, 2011 | 05:02 PM
HPEVOX's Avatar
3rd gear pull, 50 degree, engine warm
Time,RPM (RPM),MAF (V) (V),Ign. Advance (°),Knock Retard (CA),WGDC Fine (%),Abs. Pressure (PSI),Boost Pressure (PSI),WGDC Coarse (%),Load Boost/Fuel (Load)
0.00,3631,3.59,16.00,0.00,20.78,24.00,9.93,38.00,1 49.38
0.08,3623,2.89,20.00,0.00,0.00,19.14,5.08,38.00,11 1.25
0.16,3712,2.50,27.00,0.00,0.00,15.45,1.38,38.00,83 .44
0.26,3703,2.83,32.00,0.00,4.31,16.97,2.90,38.00,89 .06
0.34,3799,3.24,27.00,0.00,20.78,18.93,4.86,38.00,1 17.81
0.44,3803,3.30,24.00,0.00,67.45,22.84,8.77,38.00,1 38.75
0.52,3912,3.83,18.00,0.00,92.16,25.96,11.89,38.00, 170.62
0.62,3886,3.75,15.00,0.00,92.16,29.08,15.01,38.00, 196.25
0.70,4012,3.89,13.00,0.00,92.94,32.20,18.13,38.50, 218.12
0.80,4041,3.95,10.00,0.00,93.33,34.95,20.88,40.00, 240.62
0.88,4166,4.04,8.00,0.00,94.90,36.48,22.41,40.50,2 54.69
0.98,4194,4.22,7.00,0.00,92.16,37.49,23.42,42.00,2 61.88
1.06,4302,4.24,8.00,0.00,93.73,37.64,23.57,43.00,2 62.81
1.16,4350,4.14,7.00,1.05,94.12,36.91,22.84,44.00,2 50.94
1.24,4464,4.18,8.00,1.05,96.47,34.95,20.88,45.00,2 34.69
1.34,4499,3.73,10.00,1.05,96.47,33.14,19.07,47.00, 221.56
1.44,4621,3.75,11.00,1.05,96.47,31.40,17.33,47.50, 210.94
1.54,4681,3.73,13.00,1.05,96.47,30.46,16.39,48.50, 204.38
1.62,4740,3.81,14.00,1.05,96.47,29.66,15.59,49.50, 198.12
1.72,4819,3.79,15.00,1.05,100.00,28.86,14.79,51.00 ,194.69
1.82,4876,3.83,15.00,1.05,100.00,28.86,14.79,52.00 ,194.38
1.92,4950,3.96,16.00,0.70,100.00,28.86,14.79,53.00 ,196.25
2.00,5010,4.06,15.00,0.70,100.00,29.08,15.01,54.00 ,199.38
2.10,5081,4.08,15.00,0.70,100.00,29.66,15.59,54.50 ,203.12
2.22,5137,3.96,14.00,0.70,100.00,30.24,16.17,56.00 ,208.12
2.32,5219,4.16,14.00,0.70,100.00,31.04,16.97,57.00 ,210.62
2.40,5296,4.04,15.00,0.70,100.00,31.40,17.33,57.50 ,212.50
2.50,5345,4.06,15.00,0.70,100.00,31.98,17.91,58.50 ,214.38
2.60,5426,4.12,15.00,0.70,100.00,32.56,18.49,59.50 ,214.38
2.70,5474,4.06,15.00,0.70,100.00,32.78,18.71,61.00 ,213.75
2.80,5572,4.12,15.00,0.35,100.00,32.78,18.71,62.00 ,211.88
2.90,5626,4.10,15.00,0.35,100.00,32.78,18.71,63.00 ,210.31
3.00,5699,4.12,15.00,0.35,100.00,32.56,18.49,64.00 ,210.31
3.10,5760,4.18,16.00,0.35,100.00,32.56,18.49,65.00 ,209.69
3.22,5836,4.20,16.00,0.35,100.00,32.41,18.35,66.50 ,209.38
3.30,5928,4.16,17.00,0.35,100.00,32.41,18.35,67.50 ,208.12
3.40,5976,4.28,17.00,0.35,100.00,31.98,17.91,68.50 ,206.88
3.48,6048,4.20,17.00,0.70,100.00,31.83,17.77,69.50 ,206.56
3.58,6102,4.30,17.00,0.35,100.00,31.62,17.55,71.00 ,205.62
3.66,6167,4.22,18.00,0.35,100.00,31.40,17.33,71.50 ,205.31
3.76,6213,4.28,18.00,0.35,100.00,31.18,17.11,73.00 ,204.38
3.84,6291,4.32,18.00,0.35,100.00,31.04,16.97,74.00 ,204.69
3.94,6334,4.34,18.00,0.35,100.00,30.82,16.75,75.00 ,204.69
4.02,6410,4.28,20.00,0.35,100.00,30.82,16.75,76.00 ,205.00
4.12,6454,4.32,20.00,0.35,100.00,30.82,16.75,77.00 ,204.38
4.20,6516,4.30,20.00,0.35,100.00,30.82,16.75,78.00 ,205.00
4.30,6590,4.38,20.00,0.00,100.00,30.82,16.75,79.00 ,204.06
4.40,6631,4.38,20.00,0.00,100.00,30.60,16.53,80.00 ,203.75
4.50,6708,4.38,20.00,0.00,100.00,30.60,16.53,81.00 ,203.44
4.58,6769,4.34,21.00,0.35,100.00,30.60,16.53,82.00 ,203.12
4.68,6818,4.34,21.00,0.35,100.00,30.46,16.39,83.00 ,202.50
4.76,6868,4.39,21.00,0.35,100.00,30.46,16.39,84.00 ,200.62
4.86,6931,4.36,21.00,0.35,100.00,30.24,16.17,84.50 ,198.75
4.94,6989,4.38,21.00,0.35,100.00,30.02,15.95,85.50 ,197.81
5.04,7035,4.39,21.00,0.35,100.00,29.88,15.81,86.50 ,196.56
5.12,7095,4.36,22.00,0.00,100.00,29.44,15.37,87.00 ,195.31
5.22,7149,4.32,22.00,0.00,93.33,28.28,14.21,88.00, 192.50
5.30,7211,3.71,-9.00,0.00,0.00,17.33,3.26,84.00,106.25
Old Mar 16, 2011 | 05:52 PM
Jookies's Avatar
The stage 1 Cobb SF tune has me hitting 24.5-25.5 PSI lol. And thats with the LWG map! (hit 27 on the reg one) I'd say either injen sucks, or you have a leak!
Old Mar 17, 2011 | 11:29 AM
HPEVOX's Avatar
Todays run after more t-bolts and tighter ratchet hand lol same gear, but 72 degrees and sunny. Knock is a lot better and boost doesn't seem to fluctaute as much? Any advice?
0.00,3231, 2.09, 40.00, 0.00, 0.00, 6.82, -7.25, 34.50, 31.25
0.10,3248, 2.13, 40.00, 0.00, 0.00, 6.82, -7.25, 34.50, 31.25
0.18,3248, 2.11, 40.00, 0.00, 0.00, 6.82, -7.25, 34.50, 31.56
0.28,3256, 2.15, 40.00, 0.00, 0.00, 7.25, -6.82, 34.50, 34.06
0.36,3263, 2.42, 40.00, 0.00, 0.00, 8.99, -5.08, 35.00, 46.25
0.46,3292, 2.42, 38.00, 0.00, 0.00, 9.57, -4.50, 35.00, 50.94
0.54,3285, 2.42, 37.00, 0.00, 0.00, 10.95, -3.12, 35.50, 57.19
0.64,3319, 2.77, 33.00, 0.00, 25.49, 13.49, -0.58, 36.00, 74.38
0.72,3339, 2.79, 31.00, 0.00, 30.20, 14.21, 0.15, 36.00, 83.44
0.82,3364, 2.91, 30.00, 0.00, 69.41, 16.03, 1.96, 36.50, 92.50
0.90,3413, 2.95, 26.00, 0.00, 90.20, 17.33, 3.26, 37.00, 106.25
1.00,3426, 3.07, 25.00, 0.00, 90.98, 18.71, 4.64, 37.50, 114.38
1.08,3483, 3.32, 24.00, 0.00, 97.25, 20.09, 6.02, 38.00, 125.62
1.18,3519, 3.36, 22.00, 0.00, 97.25, 21.83, 7.76, 38.00, 140.00
1.26,3581, 3.48, 19.00, 0.00, 97.25, 23.79, 9.72, 38.00, 154.06
1.36,3621, 3.61, 15.00, 0.00, 97.25, 26.32, 12.26, 38.00, 170.94
1.44,3703, 3.79, 14.00, 0.00, 97.25, 29.30, 15.23, 38.00, 190.94
1.54,3755, 3.95, 11.00, 0.00, 97.25, 32.20, 18.13, 38.00, 211.88
1.62,3834, 3.91, 9.00, 0.00, 97.25, 34.74, 20.67, 38.00, 235.00
1.72,3933, 4.12, 8.00, 0.00, 97.25, 36.48, 22.41, 38.00, 250.00
1.80,3970, 4.06, 7.00, 0.00, 94.90, 36.91, 22.84, 39.00, 245.31
1.90,4093, 4.10, 8.00, 0.00, 96.47, 36.26, 22.19, 39.50, 236.56
1.98,4143, 3.57, 10.00, 0.00, 97.25, 35.32, 21.25, 41.00, 227.19
2.08,4237, 3.83, 10.00, 0.00, 98.82, 34.52, 20.45, 42.00, 222.19
2.16,4325, 3.96, 11.00, 0.00, 100.00, 33.58, 19.51, 43.00, 218.12
2.26,4375, 3.63, 11.00, 0.00, 100.00, 32.99, 18.93, 44.50, 215.62
2.34,4491, 4.18, 13.00, 0.00, 100.00, 32.56, 18.49, 45.50, 215.00
2.44,4540, 3.85, 12.00, 0.00, 100.00, 32.20, 18.13, 47.00, 215.00
2.52,4624, 3.89, 13.00, 0.00, 100.00, 32.20, 18.13, 48.00, 215.00
2.62,4699, 4.16, 14.00, 0.00, 100.00, 32.20, 18.13, 49.00, 215.00
2.70,4773, 3.83, 14.00, 0.00, 100.00, 32.20, 18.13, 50.00, 215.31
2.80,4838, 3.89, 13.00, 0.00, 100.00, 32.20, 18.13, 51.50, 215.31
2.88,4937, 4.06, 15.00, 0.00, 100.00, 32.41, 18.35, 53.00, 214.06
2.98,4993, 4.12 15.00, 0.00, 100.00, 32.41, 18.35, 54.00, 211.88
3.06,5084, 4.08, 15.00, 0.00, 100.00, 32.20, 18.13, 54.50, 210.94
3.16,5133, 4.02, 15.00, 0.00, 100.00, 32.41, 18.35, 56.00, 210.62
3.26,5222, 4.00, 15.00, 0.00, 100.00, 32.41, 18.35, 57.00, 208.44
3.36,5289, 3.96, 16.00, 0.00, 100.00, 32.20, 18.13, 58.00, 205.31
3.46,5356, 4.04, 17.00, 0.00, 100.00, 32.20, 18.13, 59.00, 203.75
3.58,5442, 4.20, 17.00, 0.00, 100.00, 31.98, 17.91, 60.00, 201.25
3.68,5522, 4.16, 17.00, 0.00, 100.00, 31.83, 17.77, 61.50, 198.12
3.78,5601, 4.08, 17.00, 0.00, 100.00, 31.83, 17.77, 62.50, 196.88
3.86,5677, 4.02, 18.00, 0.00, 100.00, 31.62, 17.55, 63.50, 195.94
3.96,5729, 3.98, 18.00, 0.00, 100.00, 31.40, 17.33, 64.50, 196.25
4.06,5813, 4.04, 18.00, 0.35, 100.00, 31.83, 17.77, 65.50, 198.12
4.16,5859, 4.18, 17.00, 0.35, 100.00, 31.83, 17.77, 67.00, 199.06
4.27,5947, 4.26, 18.00, 0.35, 100.00, 31.98, 17.91, 68.00, 200.62
4.37,6004, 4.14, 18.00, 0.35, 100.00, 32.20, 18.13, 69.50, 202.50
4.49,6087, 4.26, 17.00, 0.35, 100.00, 32.41, 18.35, 71.00, 204.38
4.59,6172, 4.22, 18.00, 0.35, 100.00, 32.41, 18.35, 72.00, 205.00
4.71,6239, 4.30, 19.00, 0.00, 100.00, 32.41, 18.35, 73.50, 204.69
4.81,6312, 4.32, 19.00, 0.00, 100.00, 32.20, 18.13, 75.00, 205.62
4.93,6410, 4.30, 20.00, 0.00, 100.00, 32.41, 18.35, 76.50, 205.62
5.03,6471, 4.30, 20.00, 0.00, 100.00, 32.20, 18.13, 77.50, 205.94
5.11,6550, 4.34, 20.00, 0.00, 100.00, 31.98, 17.91, 78.50, 205.31
5.21,6613, 4.32, 20.00, 0.00, 100.00, 31.98, 17.91, 79.50, 204.06
5.29,6678, 4.39, 20.00, 0.00, 100.00, 31.83, 17.77, 80.50, 205.00
5.39,6732, 4.36, 20.00, 0.00, 100.00, 31.83, 17.77, 81.50, 203.12
5.47,6805, 4.39, 22.00, 0.00, 100.00, 31.40, 17.33, 82.50, 201.25
5.57,6849, 4.34, 22.00, 0.00, 100.00, 31.40, 17.33, 83.50, 199.38
5.65,6918, 4.38, 22.00, 0.00, 87.45, 30.24, 16.17, 88.50, 195.31
5.75,7218, 3.40, -10.00, 0.00, 0.00, 17.98, 3.92, 84.50, 106.56
Old Mar 17, 2011 | 11:42 AM
fostytou's Avatar
EvoM Community Team
If it wasn't obvious... it is really difficult to read the log in that format and generally people are pretty busy/lazy when it comes to all of them reformatting it in the same manner.
Not trying to be a jerk here, but it might help you out to put it in something that was a bit more clear (graph or column)
Old Mar 17, 2011 | 05:11 PM
HPEVOX's Avatar
I went back and reformatted and pasted it in and it wouldn't allow it in column form for some reason?? took like 30 min and got nothing lol gar. Thanks though just letting everyone know I actually did try to lol
Old Mar 17, 2011 | 05:35 PM
ODUB's Avatar
attach the log file instead of copying and pasting the data
Old Mar 17, 2011 | 05:46 PM
HPEVOX's Avatar
Question
It won't let me on this forum? I can on others though.. It says invalid file when I try to attach on evom. sorry guys I really am trying lol
Old Mar 17, 2011 | 07:11 PM
COBB Tuning's Avatar
Boost is a bit low but its not knocking
Old Mar 18, 2011 | 06:17 AM
HPEVOX's Avatar
Should I try and remove the pill or would that bee Too much?
Old Mar 18, 2011 | 12:28 PM
BakaUnchi's Avatar
I would to see if it helps you hit target
Old Mar 18, 2011 | 12:33 PM
JDMEvo9RS's Avatar
Have you considered that you boost gauge is off?
Old Mar 18, 2011 | 12:52 PM
HPEVOX's Avatar
The AEM digital gauge and Cobb read about identical at peak boost. Vacuum is only thing that is diff b/t the 2.
I may try it without the pill Sunday and post results.
