IDC maxxed out?
Old Mar 21, 2011 | 07:15 AM
tephra's Avatar
LPG power??
Old Mar 21, 2011 | 09:54 AM
chetrickerman's Avatar
Veteran: Army
Originally Posted by xhomm02
Yes, they are updateted I think every 4 minutes running int the right mode (idle, closed loop cruise)
what about when at WOT?
Old Mar 21, 2011 | 11:02 AM
xhomm02's Avatar
While in open loop trims are not calculated, but middle trim is used to calculate IPW.
Old Mar 21, 2011 | 11:06 AM
xhomm02's Avatar
Originally Posted by fostytou
Agreed... get a wideband! (especially if you have a LPG setup that is probably pushing alot of power). If you can install a LPG setup, surely you can install a wideband.
LPG does not provide more power that pump gas (actually about 3% less), but is much cheaper here :-).
It is not so easy to get anything for cars here - everything is horribly expensive, like twice or 3 times the price in US :-((((( That´s why I will order WB in US as well...
Any experience with this? http://www.motorsportsinnovations.co...gauge_kits.htm
Old Mar 21, 2011 | 07:10 PM
Veteran: Army
then what does the ECU use to make AFR's richer if there is a lean spot in the tune?
Old Mar 21, 2011 | 07:25 PM
tephra's Avatar
the ECU doesn't know there is a lean spot in the tune...
at WOT anyways
before my "disable LTFT from affecting WOT" the ECU would use the LTFT High as a correction for running WOT... But I figured that was bad/dangerous so I changed that behaviour with that patch...
Old Mar 21, 2011 | 08:04 PM
Veteran: Army
at WOT anyways
ok, but doesnt the ECU read the O2 sensor, and it would see that the AFR is 12 when it should be richer, so next run the ECU inputs a trim to increase fuel there?
or am I wrong?
Old Mar 21, 2011 | 08:07 PM
tephra's Avatar
your wrong
The O2 sensors are narrowband.
This means they are only good for reading above or below 14.7:1. Nothing else.
ie NB's will say "your above 14.7", or "your below 14.7", they dont tell you by how much...
Old Mar 21, 2011 | 08:11 PM
Veteran: Army
damn. then i dont get this.
when i reset my ECU, it resets my fuel trims. and when i do a WOT run, my AFR's are around 12's until 6k rpms, but then after a few WOT runs, my AFR's are at low 11's all the way til redline.
Old Mar 21, 2011 | 08:14 PM
tephra's Avatar
have you done my patch:
https://www.evolutionm.net/forums/ev...t-fueling.html
Probably not, so that means your LTFT_High is affecting your WOT pulls.
But because of how the NB's work its pretty useless, hence why I disable it...
Old Mar 21, 2011 | 08:17 PM
Veteran: Army
not that i know of.
What would your patch change about this?
Old Mar 21, 2011 | 08:18 PM
tephra's Avatar
read the thread...
Old Mar 21, 2011 | 08:22 PM
Veteran: Army
ok, thanks for the info
Old Mar 22, 2011 | 08:09 AM
fostytou's Avatar
EvoM Community Team
Apologies then... I didn't know a ton about the technology, but I was always under the impression that it provided a boost in fuel economy and power in diesel engines (and that people on pump gas didn't run it because large turbo-diesels had more room for a big propane tank)
Old Mar 22, 2011 | 08:45 AM
xhomm02's Avatar
No no, it is widely used in petrol engines here in Europe due to low cost. But however I will get the WB to be sure it works right, even though I see only very occasional 1-2 knock sum at WOT.
