IDC maxxed out?
Well you said that 120% idc is Max
what about When I hit 125% in colder days? Usually it was 115-120
is that really bad even if there is no problems with knocking ?or can I live with it ?
I’m running stock turbo injectors almost everything around and my mods are:
Forged engine custom exhaust dw65c 3 port solenoid, bc air filter
35 psi peak boost
29 psi at 6 krpm 12-13 Timing advance
93 octane
35 psi peak boost
93 octane
35 psi peak boost
93 octane
35 psi peak boost
93 octane
35 psi peak boost
93 octane
35 psi peak boost
93 octane
Who the **** is tuning this car and actively trying to explode it?
I leave in europe so you won’t know.
base map my tuner. Corrections timing and boost by myself
well When idc was about 117 I was relaxed but 125 is a lot
Hmm, well engine is running for a 1 year 15k miles few track days and only few small issuesMy map was almost maxed out with load targets and now finally I focused on load corrections. Now I’m trying to be below 300 load at 6k rpm and this allows me to be on 120% idc
I’m happy with that. As my tuner said “you need to be aware user of a high modified car” so I’m I was driving 1* more timing but on 5 gear at 130mph sometimes was knocking
I’m happy with that. As my tuner said “you need to be aware user of a high modified car” so I’m I was driving 1* more timing but on 5 gear at 130mph sometimes was knocking Thread
DaEvoPusha
70
Oct 6, 2016 11:53 AM
Chet3215
Jul 24, 2016 11:51 AM
BlueByU2004GSR
Evo X Dyno Results
13
May 3, 2016 05:05 PM
