IDC maxxed out?
Old Mar 19, 2011 | 03:22 PM
xhomm02's Avatar
IDC maxxed out?
Hi,
I run stock car with these mods: Green panel filter (with Cobb HKSPF MAF calibration), Miltek HFC + TBE
While tuning WGDS and load target toady I found out in log that my IDC is maxxed out in 6-7k RPM WOT (101%).
Is it common to max out IDC on stock turbo/cams???
Old Mar 19, 2011 | 05:39 PM
Golden's Avatar
Max is actually 120%. 100% is ~ 80% from an injector point of view. You are fine, but if you make more power you may want to add injectors.
Do you have a new Fuel Pump Relay? Have you checked your Fuel Pressure Regulator's vacuum hose?
Old Mar 19, 2011 | 11:00 PM
tephra's Avatar
whats your AFR at 6-7k?
Old Mar 20, 2011 | 03:04 AM
xhomm02's Avatar
Any explanation for this?
I actually run LPG (with it´s own ECU and injectors), but IPW for LPG injectoors is read from stock ECU.
Old Mar 20, 2011 | 03:05 AM
xhomm02's Avatar
I am just planning to get WB :-( Running Cobb stage 2 fuel map.
Old Mar 20, 2011 | 04:05 AM
tephra's Avatar
well 100% IDC isn't too bad..
but it is useful to know your AFR- you might be running 10.5AFR - hence the high IDC...
Old Mar 20, 2011 | 06:44 AM
xhomm02's Avatar
Yes, according to the map I should be somewhere near 10,5. As I do not have WB, I prefer being richer for safety.
Is it true that 100% IDC is like 80% in real? (like in the post before?) I log IDC via Accessport.
Old Mar 20, 2011 | 06:46 AM
tephra's Avatar
Well I am not sure what the AP logs for IPW/IDC, so I can't be 100% sure.
But what _we_ log you can get the IDC upto about 115/120 before adding more fuel to the map doesn't make any change.
Best to keep it under 100% regardless
Oh - and your map AFR is only a ROUGH estimate on the actual AFR...
Old Mar 20, 2011 | 10:29 AM
xhomm02's Avatar
Thank you for info!
I just just hope the AFR map is close to the real AFR :-)
Old Mar 20, 2011 | 11:41 AM
chetrickerman's Avatar
Veteran: Army
kind of on the same topic, but how long does it take fuel trims to build?
Old Mar 20, 2011 | 12:41 PM
xhomm02's Avatar
I think it is 4 minutes interval to recalculate.
Old Mar 20, 2011 | 05:47 PM
Golden's Avatar
Originally Posted by xhomm02
Thank you for info!
They never really are.
Old Mar 20, 2011 | 06:49 PM
Veteran: Army
are you saying it takes 4 minutes to recalculate the fuel trims?
Old Mar 21, 2011 | 01:40 AM
xhomm02's Avatar
Yes, they are updateted I think every 4 minutes running int the right mode (idle, closed loop cruise)
Old Mar 21, 2011 | 06:55 AM
fostytou's Avatar
EvoM Community Team
Thank you for info!
Agreed... get a wideband! (especially if you have a LPG setup that is probably pushing alot of power). If you can install a LPG setup, surely you can install a wideband.
