Logging "Gear In Use" in EvoScan
Old Mar 21, 2011 | 06:11 AM
RS200Z's Avatar
I currently own a 2008 EDM SST (ECU ID 53050009). When I tried logging the "Gear In Use" parameter in EvoScan v2.8, the value returns doesn't make sense.
Currently the address in EvoScan is 23808866 and Eval is x/22.6 which is probably incorrect.
Does anyone have the right address and/or formula?
Old Mar 21, 2011 | 12:39 PM
saytheb's Avatar
The values are not "1/2/3/4/5/6" but instead ranges of values to represent each gear. I don't have the breakdown handy.. maybe someone who does can post it?
The easiest way may be to find exact for you. In 1st gear, log this value throughout your RPM band (from idle to rev limit, or lower if you'd like), then do this again for the next 5 gears. This should give you your "ranges" for the values in each gear.
Old Mar 21, 2011 | 01:55 PM
RazorLab's Avatar
I believe it's in RPM/MPH like the ECU uses for "gear in use"
Evo X GSR
* 1st gear = 175 rpm/mph
* 2nd gear = 119.3 rpm/mph
* 3rd gear = 88.4 rpm/mph
* 4th gear = 67 rpm/mph
* 5th gear = 46.5 rpm/mph
Evo X MR
* 1st gear = 194.3 rpm/mph
* 2nd gear = 125.9 rpm/mph
* 3rd gear = 93.2 rpm/mph
* 4th gear = 70.3 rpm/mph
* 5th gear = 53.6 rpm/mph
* 6th gear = 41.2 rpm/mph
I could be wrong, I haven't logged it in ages.
Old Mar 21, 2011 | 06:58 PM
saytheb's Avatar
I believe you are correct, Bryan. These are the numbers I have courtesy of Gunzo.
160+ 1st
130-115 2nd
110-90 3rd
80-60 4th
40-50 5th
less than 40 = 6th
Old Mar 21, 2011 | 08:47 PM
RS200Z's Avatar
Thanks for the tip fellas, will check it out again.
BoMbA_CaJu
Nov 14, 2015 05:41 PM
WRC-LVR
Sep 23, 2013 08:40 PM
crimson red
Apr 12, 2011 07:25 AM
MINO
Nov 7, 2008 11:28 AM
chmodlf
Jan 22, 2008 04:38 AM
