Why doesn't my "RPM Per MPH Xover"-setting work?
Hey guys!
After installing my 3-port I'm tuning the boost and it works great, but the gear based setting doesn't work...
I set it to "80" (it's a MR), yet in 3rd gear he still uses the "high gear range" tables!?!?
What could be the cause for this?
EDIT: Just checked the definitions and they ARE set for MPH, so it SHOULD work...
I think I just found my answer in the following thread... Wrong definition address...
https://www.evolutionm.net/forums/ev...t-control.html
You already did find it for me, but in the other thread... ;-D
So thanks, either way!
Actually I'm already back from finishing up the Wastegate Duty Cycle and BTEL maps. Worked pretty well on the Autobahn in fifth gear... Tops at about 210kph/130mph. I was lucky as well. Every time I had corrected the map and drove back onto the Autobahn and IMMEDIATELY had the perfect hole in traffic to do a complete 5th gear pull. 3 pulls total.
All done for now!
Now off to switch to summer-tires and optimizing corner weights...
I call it Evo-Kaizen... :-D
All done for now!
chrylaser
Oct 17, 2013 11:51 AM
eastxcelerate
Apr 29, 2009 07:37 AM
